Old 07-25-2010
rpearlberg is on a distinguished road
Two questions
I have a couple quick questions.
For some reason, I cannot open the seacock to drain the galley sink. I found it and know it's the right one, but can't get it to move at all. Any suggestions???
We have an Edson Pedestal on our Pearson 303. I know there is a way to use a tiller if there is ever a problem with the Edson. Does anyone know how to do this or where to find it?
Thanks!!!
Old 07-25-2010
DwayneSpeer's Avatar
Old Fart
DwayneSpeer is on a distinguished road
The seacock is frozen. You need to loosen the jam nut and loosen the nut that holds the innerds in just a tiny bit then spray the thing liberally with a lubricant such as WD40 and let it soak for several hours or even days. Then try it. If that doesn't work you may try loosening the nut further and tapping on the opposite end with a small hammer to break it free.
As for the emergency tiller, they usually fit over the rudder post. At least mine does.
Hey, can one of you guys pass me a crab?
Old 07-25-2010
WanderingStar is on a distinguished road
Penetrating oil or heat if it is a tapered bronze plug, or metal ball valve. It might have a synthetic ball, in which case neither of those is a good idea.
Old 07-25-2010
mitiempo's Avatar
I wouldn't put much heat on any ball valve. Regardless of the ball material there are teflon seals and they don't like heat.
With a tapered all metal seacock heat is ok.
Brian
Old 07-25-2010
It's a Perko Bronze seacock, if that means anything....
Old 07-25-2010
mitiempo's Avatar
It may be an older tapered plug type or a ball valve - Perko makes both types.
Brian
Old 07-26-2010
Irrationally Exuberant
arf145 is on a distinguished road
Regarding that emergency tiller. It won't be just any old tiller, but something made to fit over the rudder post, as Dwayne said. On the Pearson 28, it's a big honking piece of aluminum shaped like a bent L with a notch in one end to fit over a bolt that goes through the rudder post. Did you get one with the boat? Look for a deck port or some other access point right above the rudder.
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 07-26-2010
paul323 is on a distinguished road
On my Pearson 323, access to the rudder post is by an aluminium deck port just behind the wheel, on the 'floor' in the middle of the cockpit. Easily recognised as it is (a) above the rudder where it hinges and (b) the port has two small recessed holes where a special "key" fits in to unscrew it. As arf145 said, the tiller itself is a substantial L-shaped aluminium tube, maybe 4' long (total), formed to a hex socket on one end to fit onto the rudder post. Check out the lazarettes - it is often buried in there (hopefully not buried too deep, 'cost when you need it, you really need it!!)
Old 07-26-2010
Oh yeah, that emergency tiller will be buried, yet always waiting to wreak havoc when moved. After countless nicks and bangs from that thing, I finally mounted it on the wall of the lazarette this past winter. Easy to get at when needed, but no longer threatening to crack a thru hull when heeled.
arf145
1987 Pearson 28-2
Chesapeake Bay
Noob questions about buying a first Sailboat Polypterus Learning to Sail 17 06-10-2010 12:44 PM
Looking to buy a boat in the DC area and have some questions FRRizzo111 Boat Review and Purchase Forum 10 06-02-2004 06:20 PM
New X-46 -- New Intro -- First Questions John-A Boat Review and Purchase Forum 8 01-29-2004 08:21 PM
a few specific design questions jbarros Boat Review and Purchase Forum 5 10-02-2003 02:13 PM
