Jib/genoa lines - Page 2 - SailNet Community
post #11 of 14 Old 07-29-2010
Bristol 45.5 - AiniA
Or ...
Originally Posted by sck5 View Post
imagine that shackle flogging around some time. I wonder what it would hit? You? Fiberglass? A port or hatch?
upside the head! I have been hit by bowline when forward getting a jib down in a squall - nasty enough without it being a hunk of metal.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #12 of 14 Old 07-29-2010
pdqaltair's Avatar
Again, we all think about the boats we have and not the boats of others.
On a Hobie cat, for example, the jib is cut too high to hit anything, and there is no forward deck. On my PDQ, the tack of the jib is too high to hit anything other than the mast. If I roll in just a little, not even that. Low genoas have their downside... that and every port-tack boat that has tried to run me down has had one .
That said, I use a cow hitch on my genoa.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #13 of 14 Old 07-30-2010
dhays's Avatar
Good point about all boats being different. However, using two separate lines, tied to the clue with bowlines is the only way I'd go. Maybe it is just 45+ years of habit. I don't leave my jib sheets tied to the sail. They get removed and stowed. It is quicker and easier to tie a bowline than use most shackles. It also gives more flexibility than using a single line and cow hitch.
Dave
Dave
47⁰20'11.7" N
122⁰35'20.8" W
M/V Kinship, North Pacific 43
Formerly
S/V Legacy, Catalina 400 MkII, Hull #328
dhays is offline
post #14 of 14 Old 07-30-2010
San Juan 21 MKII
lydanynom's Avatar
Originally Posted by dhays View Post
Good point about all boats being different. However, using two separate lines, tied to the clue [clew] with bowlines is the only way I'd go. Maybe it is just 45+ years of habit. I don't leave my jib sheets tied to the sail. They get removed and stowed. It is quicker and easier to tie a bowline than use most shackles. It also gives more flexibility than using a single line and cow hitch.
Dave
In my case I have two headsails, a working jib and a genoa, and the sheets for each go to different tracks and cleats, so I wouldn't gain anything by switching to a method that was easier to remove from the sail.
lydanynom is offline
