Old 04-08-2003
kmeeks's Avatar
kmeeks is on a distinguished road
Send a message via Yahoo to kmeeks Send a message via Skype™ to kmeeks
cost of a new cabin sole?
just wondering if anyone has had a new cabin sole made - I have a 32 ft. islander.
Old 04-09-2003
williamjchampion is on a distinguished road
It cost me about $1500 3 years ago to have the cabin sole cut out, new mahogany stringers installed and a new sole. It''s 3/4 inch marine ply glassed on top. (Didn''t replace the teak and holly. I went with dri-dek on top of the new sole. If you''re doing it, take the opportunity to give yourself decent access to the bilge. I had two foot long access plates, which wouldn''t give you access to the keel bolts, etc. Now I have a 6 foot long mahogany access plate. If you have wiring running through the bilge, ripping out the cabin sole is also a great opportunity to install conduit (PVC pipe) for electrical runs.
Old 04-09-2003
JimCoache is on a distinguished road
I have a 31'' Irwin I am replacing the cabin sole on. Using 3/4" teak & holly marine plywood. Material cost is a little over $400.00 and doing the work myself.
Old 04-09-2003
Irwin32 is on a distinguished road
Irwin: Where did you get the plywood? What are you doing about the edges?
I have seen a couple of boats in my area that used a flooring they bought from Century Tile that looked pretty good, It was fake wood - say mahogany or cherry, that is made in board size strips. It is somewhat flexible and I believe it is made of fibergalss. It even has the 1/8" spacing in between boards.
Advice refinishing teak and holly sole mcagney Gear & Maintenance 11 09-24-2009 07:03 AM
ISLANDER 29 CABIN SOLE mauricefrompolo Gear & Maintenance 2 03-02-2009 10:57 PM
Cabin Step Mast JNBDeVore Gear & Maintenance 6 10-03-2007 12:35 PM
Cruising Advice Needed!!! 2 or 3 cabin for 3 single guys? robbieturner Cruising & Liveaboard Forum 5 10-17-2001 05:26 AM
vinyl cabin sole creek Gear & Maintenance 0 03-20-2001 05:47 AM
