07-30-2010
Assuming that your sink has straight water pipes, ie no fittings on the bottom, all you need are the compression fittings. Mine took a 3/8 fitting that I got from Home Depot. You slide the compression nut (that comes with it) on first and then what looks like a smooth washer on after. This compression nut will then screw into the piece connected to your water line. At least it did on mine.
Hope this helps.
Ed Reiss
Being There
Freedom F38 #154
out of Marion, MA
