07-30-2010
ancient mariner
can you disassemble the transmission have it machined & a sleeve installed? years ago i had that happen on the rear axle of a 1 ton truck. i used heavy duty loctite for loose fit ups. i also used it on couplings that were a loose fit on the propeller shaft. this worked out OK.
Liberals are people who care about others. Freethinkers are not constrained by the myths of religion.
