Wheel maintanence - SailNet Community
post #1 of 3 Old 04-09-2003 Thread Starter
Wheel maintanence
The PO replace the tiller in my boat with a wheel. I don''t know much about maintenance for the steering. I took a look under the cockpit at the control lines. They are plastic outside with the steering cables inside. Periodically they have little nubs on them and grease has come out around the nubs. This can''t be normal, can it? Also, what sort of maintenance does this set up require?
Thanks in advance.
Kevin
bantrybayboston is offline
post #2 of 3 Old 04-09-2003
Moderator
Jeff_H's Avatar
Wheel maintanence
That sounds like a pull-pull sheathed (conduit) cable system, which works roughly the same way that a motorcycle throttle cable works. Because careful alignment of the components are not required it is a popular after market system since the components are easier to install.
The bad news is that it is also one of the highest friction systems and so requires more energy to make the same adjustment as compared to lower friction systems. The sheathed cable systems tend to be a little less reliable than most other systems as corrosion inside the cable covers can go undetected, and crushing or movement of the cable covers can result in sloppy steering. This is really my least favorite system except hydraulic.
These come on a variety of constructions but it sounds like you have a system with grease cups to lubricate the cables. This is better than the alternatives where you have to try to work in grease from the ends. (Very in effective. The grease helps reduce friction a bit, reduces wear and tear on the cable sheath and also reduces corrosion of the cable so it is important to maintain grease in the system.
Jeff_H is offline
post #3 of 3 Old 04-10-2003
Wheel maintanence
Teleflex-Morse have a lot of information on their website, including steering/cable systems.
www.teleflexmorse.com
Good luck!
Gord
GordMay is offline
Tiller to wheel conversion costs? 808state Gear & Maintenance 13 06-30-2012 07:11 PM
KISS? or ... why a wheel? jbarros General Discussion (sailing related) 48 12-15-2008 04:17 PM
Autopilot & Wheel Steering MarkRamsay Gear & Maintenance 2 04-26-2002 10:49 AM
Wheel Steering cmlambpsi Racing 2 09-06-2001 05:58 PM
Steering Wheel Replacement Cahill Gear & Maintenance 0 07-19-2001 08:27 AM
