08-11-2010
Gasoline cut-off solenoids aren't common on boats, AFAIK, but they are common on a lot of fuel-injected cars, to ensure the high pressure fuel supply is cut off when the engine isn't running (i.e. after an accident). In these circuits, the solenoid is powered on during key-start by the starter circuit, and then power remains on as long as something else (i.e. ignition or fuel pressure or tach signal) is present.
As Jim said, listen for the clicks. If the solenoid is receiving NO power, it should be cutting off the fuel supply.
