Old 08-06-2010
davidpm's Avatar
davidpm is on a distinguished road
Water in the bildge
Almost every boat I see on land has water in the bilge even in the winter.
I guess it is almost impossible to keep every drop of rain and condensation out of the boat and eventually ends up in the bildge.
I worry about freezing damage though and wonder just how much damage is being done.
What do you think?
I'm not talking about any specific boat just the concept in general.
Old 08-06-2010
A lot of this depends on the boat. Keel-stepped mast boats are usually going to have some water get in via the mast. Deck-stepped masts should be dry on the interior if the boat is tight and well-found.
Yes, the water can cause problems, but it also depends on where the water is located and how much there is.
Old 08-06-2010
davidpm's Avatar
Would you elaborate please?
What I have seen most often is 3 or 4 inches in the bilge.
I'm sure the pump is ruined when it freezes but since the bilge is usually flaired a little I'm hoping that the ice will just pop up naturally.
Old 08-06-2010
garyguss is on a distinguished road
I throw in a little RV antifreeze when its on the hard and go back to sleep
Old 08-07-2010
sawingknots's Avatar
sawingknots is on a distinguished road
if you don't want to use antifreeze,put in a few corncobs[oldtimers remedy]rubber balls would work just as well,any compressible objects
Old 08-07-2010
Elaborate on what? Water expands 10% when it freezes. Depending on when and where it freezes it can cause anywhere from no real damage to splitting a hull-keel join apart if it wasn't well sealed.
Old 08-07-2010
BarryL's Avatar
BarryL is on a distinguished road
Hello,
I try to keep the water out of my bilge over the winter, but I usually do end up with some.
When I winterize the boat I pour some marine / rv antifreeze into the bilge, enough so that when I run bilge pump the antifreeze is pumped out. Then I try not to touch the bilge again. I visit the boat a bit and if I see water in the bilge I'll pump it out into a bucket and add a little bit of antifreeze.
This has been my scheme since 2007 and no problems yet.
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
Old 08-07-2010
WanderingStar is on a distinguished road
When I wintered ashore, I drilled a hole in the hull, and plugged it in spring.
Old 08-07-2010
Gene T's Avatar
Gene T is on a distinguished road
This is really quite common and done by some boatyards to unattended leaky boats to prevent damage.
Gene
Currently in Long Beach, CA
Old 08-07-2010
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
I've heard of this referred to as a 'garboard plug' which empties the bilge at a low spot. I have thought about installing something like this on my boat which has a deeper sump under the engine compartment then many shallow bilges I have seen.
I have a useless thru hull (speedo transducer) that I keep plugged but remove for winters on the hard. Water will drain out just below the engine but ice is not so good so a little RV anti-freeze in the sump is part of my winterizing process. A permanent garboard plug would be best but most sailors try to limit the number of holes they have in their boats so it isn't all that common these days.
Keeping Water Sweet paul323 Gear & Maintenance 56 04-23-2011 12:35 PM
Katadyn Water Makers ? GNWFast Gear & Maintenance 6 08-06-2010 10:36 AM
Ericson 38-blue water boat? wannabe4 Boat Review and Purchase Forum 13 08-05-2010 05:27 PM
Blue water skipper and crew ScottUK Boat Review and Purchase Forum 11 08-05-2010 04:11 PM
Waste removal and unlimited water! radioguy Cruising & Liveaboard Forum 4 08-01-2010 03:43 PM
