08-08-2010
Originally Posted by saurav16
Question for everyone, when sailing today and previously in about 10-15knot winds with the roller furling furled out all the way the mast seems to creak during gusts. Anyone else have this problem or know what it could be. I feel uneasy, I don't want to lose the rig.
What should I be checking? There is never such a creak when sailing with just the main sail. Thanks in advance for your help!
The creaking could be caused by any number of things. The fact that you don't hear it with the jib rolled up tells me that the likely culprit is one of the clevis pins on the forestay.
At the top and bottom of the headstay, you should have toggles. The toggles are there to provide articulation like a universal joint, so that when the sail fills, you aren't bending the wire. It's not uncommon for a little surface corrosion to occur on these clevis pins and for them to complain a little when moving.
The next time you go aloft, take a can of WD 40 or similar and give the clevis pins and masthead sheaves a squirt. See if that helps.
As pointed out by another poster, it's a good idea to inspect and tune your rig occasionally too. But a little creaking is not uncommon and in the majority of cases not something to be too worried about.
Ron Paul 2012
"wikijar"
