Old 08-07-2010
Barquito's Avatar
Barquito
Barquito is on a distinguished road
Help--Really dumb question
I am getting ready to fire up a new-to-me Atomic 4. I've only had outboards in the past. In my boat (Bristol 27) there only appears to be a start button. No ignition switch. So, how do I turn the beast off once (if) it gets going??!
With the battery selector set to both, the starter motor fires without turning anything else on.
Old 08-08-2010
Danny33 is on a distinguished road
Some one has the starter celinoid wired direct .
get some one to install a key switch between the battery and wire in the push button . Not hard to do ,just takes time
Old 08-08-2010
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
On our Pearson, the ignition switch is in the cabin.
Jim
s/v Abracadabra
1976 Pearson P30
Old 08-08-2010
TQA's Avatar
TQA TQA is offline
Bombay Explorer 44
TQA is on a distinguished road
Investigate the cause of this before running the engine. It is a potentially dangerous condition.
Also assuming the engine still has the standard points and ignition coil you need to be able to interrupt the supply as leaving it on without the engine running will do damage to the points and burn out the coil.
Some standard wiring layouts can be found here. Atomic Four
The previous owner may have jury rigged something that allows a start from the house battery by passing the solenoid but there are better ways of doing this.
Old 08-08-2010
seabreeze_97 is on a distinguished road
On my Bristol there's a panel beneath the electrical panel with start and stop buttons. No telling what possible fire risk you could have there. Don't trust it.
Wiring Question JimMcGee Electrical Systems 13 08-18-2010 12:40 PM
The question of ages - what boat? vtsailguy General Discussion (sailing related) 9 08-04-2010 08:54 AM
tohatsuguru 6hp question or anyone else Lolrus Gear & Maintenance 4 07-30-2010 06:02 PM
