Old 08-09-2010
sanding bunny
latitudes is on a distinguished road
Send a message via AIM to latitudes
cockpit cushions - how to secure?
We're refitting a 46 year old 33ft sailboat - she's built as a racer/cruiser capable of circumnavigation. One of our (MANY) projects is cockpit cushions. and we're fairly sure we need to physically secure them to the cockpit benches (1 inch marine ply covered w/fiberglass). We're thinking either stainless steel snaps or velcro - using epoxy to attach either the velcro or the snaps. are there other options? how do other folks deal with this?
Old 08-09-2010
I'd recommend adding a piece of bolt rope and adding bolt rope tracks to the inner corner of the benches. The inner corner of the benches isn't used, since most people's butts don't fit into the corner... and the track will hold the cushions securely in position
Old 08-09-2010
AllThumbs's Avatar
midlife crisis member
AllThumbs is on a distinguished road
I considered velcro but it's noisy.
Old 08-09-2010
ASA and PSIA Instructor
Skip the cushions, they are only usable at anchor, underway they put most movement into or out of the cockpit at risk.
Old 08-09-2010
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
Hey, now this is a little bit left of centre but given that you have a relatively small boat think about this....
On our 34'er I realised that the back cushions from our settees are a near perfect fit for our cockpit seats. That works prefectly when we are at anchor and we don't need to find somewhere to stow them.
Then we keep a couple of loose cushions and a couple of these self supporting seats for when we are out sailing. We use these...
Ocean Solutions
but I've seen other brands for sale in the US. They have non skid rubber on the base so they don't slide around.
Just a thought.
Old 08-09-2010
Minnewaska will become famous soon enough
Consider the stress you may put on whatever attaches them to the seat and whether it may tear away and ruin the cushion. That is why mine always go below, despite having strap tabs and clips. I simply consider them piece of mind when at anchor in higher winds.
Old 08-09-2010
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
I simply glued sheets of anti-skid "drawer liner" material to the underside of my cushions. now the don't move, even when the benches are wet, and there is no hardware to put stress on the cushion seams and tear free, and no velcro to wear out.
Old 08-09-2010
T37SOLARE's Avatar
Tartan 37C
T37SOLARE is on a distinguished road
Two of these Fast Eye Baby Snap clipped on to these Stainless Steel Eye Straps works great.
SOLARE
T-37 #442
Old 08-09-2010
tdw's Avatar
tdw tdw is offline
Have to say I like Jonesy's idea...think I'll do that to our other cushions.
Old 08-10-2010
Actually, only my back cushions are strapped, the seats have something like this sewn underneath. I think it is probably the stuff you put under a carpet to keep it from slipping, but it looks the same as non-skid drawer liner.
It's a few years old and doesn't stick like it used to. Also, it would not keep the cushion down if any significant wind got under it.
Consider that I have 14 custom cockpit cushions, between seats and backs. If I lose one, it will be all but impossible to replace it and not stick out as a replacement, so I'm a bit protective.
