08-13-2010
Double-sided tape to secure a fixgture onto an overhead? VERY BAD IDEA.
The adhesive will soften and let go after repeatedly being heated up by the sun-baked fiberglass it is attached to. At which point...BONK! Lighting fixture falls on your head.
Even premium brands like 3M are subject to failing in those conditions. They sell industrial "velcro" type fasteners, for holding car toll transponders onto windshields, and they have no product that will withstand long-term use in places like Florida, where the heat bakes it all day.
Epoxy really is the correct way to go, or some other permanent adhesive like urethane glue.
Bear in mind, the epoxy that was there before DID NOT FAIL. What failed was the bond between the gelcoat (or paint, since gelcoat is normally used only on the exterior of a hull) and the fiberglass.
By all means, roughen up the fiberglass (wearing a dust mask & eye protection because of the nasty fiberglass fragments) before you stick anything to it, but "tapes" and "sticky" things pretty much always fail under loads in hot boats.
