Hurth HBW 50 repair manual - SailNet Community
post #1 of 3 Old 08-13-2010 Thread Starter
Hello,
I am proud new owner of a 1974 Cal 29 with a Universal 25 and a Hurth 50 transmission. I am wondering if any of you have a copy of a repair manual for a Hurth 50 transmission. I have found the operation and maintenance manual, but that is not what im looking for. I am looking for a manual that will assist me in rebuilding my transmission.
Thanks
Troy
Adventure is knowing where you're going but not knowing how you're going to get there.
helmanta is offline
post #2 of 3 Old 02-24-2011
Hi, I Am In Thailand With A Seized Gearbox, The Result Of A Salt Water Leak Getting Into The Gearbox And Then Too Much Time Ashore. Have You Had Any Luck Getting A Repair Manual For The Box. Mine Is A Hbw150 But I Believe It Is The Same As Yours Just Older. No Incline On The Drive. Would Be Delighted To Here From You.
Cheers,rob
tartanss is offline
post #3 of 3 Old 02-25-2011
Hi Troy,
The model numbers of the transmissions have been changed after the product line was acquired. Your HBW 50 is equivalent to ZF-5M. So if you look for the info on ZF 5M you will get the info you need.
Hope that helps some.
SeaFever2000 is offline
Yanmar YSB12 or YSB8 Service Manual Mariner3339 Diesel 8 03-14-2012 02:06 AM
Two Volvo Hurth Drivetrains and props for Sale seariders Gear & Maintenance 0 08-04-2010 08:10 AM
