04-14-2003
Inflatable Dingy question??
Recently bought a sailboat which came with an inflatable dingy and a foot pump. It doesn''t leak. Problem is it will not blow up good and tight. The air inlet is about 1" in diameter and has a turn plug to cap it off. When you remove the pump fitting, quite a bit of air escapes before you can cap it. This is driving me crazy. There''s got to be a better way. Thanks
