Old 08-16-2010
saildog1 is on a distinguished road
Marine Air AC/Heat problem
I have a Marine Air 16,000 BTU unit with the touch pad control. My problem is that it is giving me a HHH code, which I think is a high pressure code. Can I repair this myself or is this something I need a HVAC tech to repair?
Old 08-16-2010
October Moon B43
MJBrown is on a distinguished road
Try cleaning the water intake filter before you do anything else.
Old 08-16-2010
Yep did that all is nice and clean
Old 08-16-2010
October Moon B43
If you're getting good water flow through the system then it's likely you may have a sensor problem. Sorry cant help out with it more than the basics. Good luck
Old 08-16-2010
SVAuspicious's Avatar
Mermaid Hunter
SVAuspicious is on a distinguished road
Even with good water flow you can have a build-up of biologics and minerals inside the A/C heat exchanger that reduces thermal conductivity.
For starters, reverse flush the entire system. If that doesn't work use an acid flush. I use Acid Magic, available at most hardware stores, that is "buffered" specifically for HVAC and swimming pool systems to reduce unwanted impact on the system.
Follow the label directions including disposal of the used acid.
sail fast and eat well, dave
S/V Auspicious
AuspiciousWorks.com
beware "cut and paste" sailors.
portable marine ac condensaion jasonr575 Gear & Maintenance 5 08-17-2010 08:25 AM
Air conditioner questions saillife Gear & Maintenance 6 08-13-2010 02:49 PM
Problem starting Yanmar 2QM20H and white smoke when running epp Diesel Engine Forum 10 07-30-2010 01:20 AM
