outboard on a Soling..? - Page 2 - SailNet Community
 1Likes
post #11 of 26 Old 08-17-2010
14432's Avatar
If you feel the need to add an outboard, follow the advice herein of those who recommend a side mount instead of a transom mount.
14432 is offline
post #12 of 26 Old 08-17-2010
paulk's Avatar
The "long-tail" solution of a garden trimmer will be even more hassle than a side-mounted OB, with less results. Solings are pretty tough boats. We had ours for about 15 years. At CORK, it would blow 25 knots all day, and we raced Olympic courses (triangle, windward, leeward, windward) with each leg two or three miles long. After the last race of the day, we'd plane seven miles back to the harbor with the spinnaker up. If there's any wind, you won't need the motor. On Long Island Sound we know about dead air as well however. We kept an oar in our boat because paddles tended to cause blisters. It was also awkward to sit on the deck, half-turned, to paddle. Paddles with looms long enough to reach the water comfortably also tended to break, because the boat is a good deal heavier than a canoe. Sitting on the bow with a foot on each side and the rudder tied 'midships, it was easy to to keep the boat moving by sculling forward, pulling with the leverage of the long oar and using the boat's momentum to advantage. Five miles is a long way, however. I would guess three was as far as we had to paddle before we got a tow.
paulk is offline
post #13 of 26 Old 10-14-2010
SO + Linge
Soling Outboard Mount + Suggestions
I have a 1974 Soling with an outboard mount on the side, which is easily removable. When I bought the boat, it had an old Evinrude two stroke, which weighed in at 35 lbs. I am now looking at new engines, and I think what it comes down to is either a Tohatsu 3.5hp or a Mercury 3.5. It's important to go with the long shaft editions, which are a tiny bit pricier but not much and will save you a lot of hassle. I would DEFINITELY not put a mount on the transom, I have seen photos online of how this looks on a Soling and I certainly wouldn't recommend it, for aesthetic reasons as well as functionality.
The Tohatsu is 45 lbs for the 3.5hp Longshaft, which is not bad and is manageable. When you are ready to sail, you just remove the engine and hang it underneath the deck, beneath the tiller (in front of the rear bulkhead). It's not as perfect as a Saildrive, but that's the price you pay for having such a beautiful boat with clean lines.
The Tohatsu is less expensive at around $950... I remember the Mercury with Longshaft being well over a grand.
I just went out and took a couple photos of my setup for you to get a general idea of what I'm talking about. I tried to attach them but since this is my first post in this forum they are preventing me from attaching images. I can email them to you if you like, or after one more post I will be allowed to add attachments. I also tried to post links to the engines but alas, the forum will not let me do this either as this is my first post here!
I myself am looking for a new engine, and I will be going with one of the above engines... have yet to make my decision.
Good luck and congratulations on the Soling purchase, it is one of the best daysailers around, and when she sits at the dock she looks like a mini America's Cupper... a look that certainly changes with the addition of a transom mount, haha!
tondus is offline
post #14 of 26 Old 10-14-2010
Just FYI, IIRC Tohatsu actually makes all of the Nissan, Tohatsu and MERCURY four-stroke outboards under 10 HP.
sailingdog is offline
post #15 of 26 Old 10-14-2010
One of None
deniseO30's Avatar
thinks this boat is just dying for someone to create a inboard drive with small air cooled diesel
My last project!
deniseO30 is offline
post #16 of 26 Old 10-14-2010
ya think???
post #17 of 26 Old 10-14-2010
One of None
deniseO30's Avatar
ok water cooled then !
My last project!
post #18 of 26 Old 10-15-2010
SO + Linge
A gas saildrive would be perfect... It would be much lighter and would only be run for short periods of time. I had thought about it in the past... but I don't think I could actually bring myself to go through with such extensive modifications to such a beautiful hull...!
tondus is offline
post #19 of 26 Old 10-15-2010
SO + Linge
VERY good to know! I think I've decided on the Tohatsu 3.5 LS for next season, then...
tondus is offline
post #20 of 26 Old 10-15-2010
That's a great engine. I had one for several seasons, until a good friend bought it off of me for a trip to the bahamas they were taking.
how to drop a mast on a soling? Ascension General Discussion (sailing related) 18 07-27-2012 07:37 AM
Pearson 31 inboard or outboard outdoorsman37 General Discussion (sailing related) 14 09-03-2010 04:58 PM
Outboard / Rudder Tiller Steering radioguy Gear & Maintenance 8 08-15-2010 08:20 PM
Help needed! anybody have a Soling or similar boat nearby? Ascension General Discussion (sailing related) 2 08-09-2010 09:55 AM
Outboard motor maintenance mpc7002 Gear & Maintenance 6 08-04-2010 07:52 AM
