Old 08-19-2010
Mariner3339 is on a distinguished road
Installing a Windvane OFF CENTER.
Anyone had experience installing a windvane off center, to allow passage through the stern? I have a windvane with a paddle that moves athwartship and two lines to connect to the tiller, not sure what make it is. Any ideas?
Old 08-19-2010
lshick is on a distinguished road
Send a message via Skype™ to lshick
My vane is on-center, and I don't have experience with one that is off-center. Based on my experience with vanes over the last 30 years though, I would look carefully at whether the vane would be "shadowed" by the hull when it's on the down side. That is, if the vane is mounted to port of center, and you're on starboard tack, the whole bulk of the hull might tend to block the wind from the vane, leading to erratic steering. We've had that happen even with our on-center vane what with weather cloths around the cockpit, outboard motors on the rail, etc.
Have you looked at Scanmar's Swing-Gate? It appears to have been invented exactly for this problem. See http://selfsteer.com/ and scroll about halfway down the page.
Larry Shick
V42-148 "Moira"
Old 08-19-2010
Another real issue is whether the vane's paddle will be submersed deeply enough on both tacks. One reason for wanting the wind vane on centerline is to ensure that the vane's paddle is submersed enough to work properly on either tack. If it is offset to one side, it will be less powerful, since it will have less area submersed, on one tack that the other which might make it less reliable on one tack.
Most boats with a transom wide enough to have a walkthru design are large enough to require a pendulum servo type vane to have enough power to steer the boat.
Old 08-19-2010
mitiempo's Avatar
A few vanes are designed to work off center, but most aren't. Post a pic of your vane and someone will tell you what it is.
Brian
Old 08-25-2010
Pamlicotraveler's Avatar
Pamlicotraveler is on a distinguished road
I have always heard to never mount off center - it's logical to me. Your problems would start at the worst time; when the paddle exits the water...
The next best thing
To playing and winning is playing and losing.
Robert Lee Castleman
Old 08-25-2010
mitiempo's Avatar
The Cape Horn self steering system can be mounted off center as long as it is kept parallel to the keel, even by enough to clear an outboard rudder.
A few Superlatives
Brian
Old 08-25-2010
SimonV's Avatar
Wish I never found SN!
SimonV will become famous soon enough
Sailomat also can be mounted off centre.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Brisbane Queensland
DELIVERY SKIPPER
Old 08-25-2010
Sequitur's Avatar
... a logical conclusion
Sequitur is on a distinguished road
Hydrovane can be mounted well off-centre. Ours is about 40 cm offset to starboard. Follow this link to Hydrovane's info on off-centre installations.
Cheers,
Michael
2007 Hunter 49
Installing a Cleat... Need Help BlueWaterMD Gear & Maintenance 11 08-09-2010 04:27 AM
Windvane self steer CRN1857 Gear & Maintenance 8 08-04-2010 01:02 PM
