08-19-2010
Seen Your Mamba
Yes, pull the tab and remove the aluminum piece. It's a seal that hides the plastic plunger. Remove the aluminum seal, insert tube in caulking gun, caulking gun depresses the plastic plunger. No danger of 4200 coming out the back.
And in fact, there is probably a moisture absorbant bit between the aluminum seal and plastic plunger - take that out and throw it in the garbage too.
Indigo 1976 Catalina Yachts C-22
