Old 08-19-2010
Julie303 is on a distinguished road
rebedding stanchion
I'm wanting to rebed the stanchions and pulpits on my 1983 Pearson 303. Is the deck solid fiberglass under these or is it cored?
Old 08-19-2010
Irrationally Exuberant
arf145 is on a distinguished road
Most likely cored. The deck might get solid right out at the edge at the deck/hull joint but I think you'll be dealing with balsa core.
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 08-19-2010
mitiempo's Avatar
I agree it is probably cored - for some bolts if not all. Core is easy to deal with but it does take longer. Here's a link by Maine Sail - a complete how-to for dealing with core and sealing it properly.
Sealing Deck Penetrations to Prevent Core Rot Photo Gallery by Compass Marine at pbase.com
Brian
Old 08-20-2010
Also, don't forget to use a decent backing plate. Lifeline stanchions give the bolts a lot of leverage to tear at the deck with, and if not backed properly, can really cause damage...
Old 08-20-2010
jbondy's Avatar
Senior Mumble
jbondy is on a distinguished road
If the 303 is like my 323, the hull-to-deck joint is based on an inward flange. The deck is cored, but not all the way to the edge where its thickness tapers, so some of the holes are thru deck that is not cored. Some holes pass thru core on the border between cored and uncored deck, so you have to seal anyway. Just don't expect to be able to dig out core material on all sides of some holes. Let's just say that the bent nail or sharpened hex key technique doesn't work so well with some of these holes. I learned that a 1/2 HP drill can generate enough force to rip itself out of your hands. It's too bad Pearson couldn't make that thinner part of the deck wide enough for the stanchion bases to go over uncored deck!
Old 08-21-2010
floatsome is on a distinguished road
Only sure way to know is to remove the bolts and carefully inspect each hole to look for core. If wet and black: hmmm -- options include cutting back and rebuilding dry core. If core is OK: pot with epoxy using the approaches mentioned below and rebuild with backing plates. In addition to a backing plate, some also add a stainless plate under the feet of the stanchion on the deck to spread leverage over a larger portion of the deck, unless the stanchion base is already has a good-sized footprint.
O'Day stanchion manufacturer inthesprings Gear & Maintenance 16 02-28-2011 07:22 PM
Stanchion base mounting blocks 4arch Gear & Maintenance 3 07-30-2010 01:42 PM
