Coiling Line - SailNet Community
post #1 of 3 Old 04-17-2003 Thread Starter
Coiling Line
I like to coil line. I usually just do the basic clockwise coil and occasionally in a figure 8. Does anyone know fancier ways to coil it?
DDogga is offline
post #2 of 3 Old 04-18-2003
Coiling Line
I don''t know any fancy ways to coil line but if you want it to run out without fouling try simply laying it back and forth across your hand. If you coil in a circle clockwise or otherwise you are introducing a twist into the line with every coil which you are not untwisting when you go to use the line.
knothead is offline
post #3 of 3 Old 04-18-2003
Coiling Line
My understanding of proper line coiling is to lay 3 strand line in a circle by twisting out any tension for the line to lay in a proper circle. I always lay it clockwise as that seems to work for me.
Double braided line should be laid in a figure 8 as that will relieve any tendency to foul. I''ve noticed that it does seem to lay more naturally in a figure 8. I have tried to lay it in a circle and it "tells" me that that is not the way it wants to be laid!
Fairwinds,
Jim
joub is offline
Releasing tension on a winched line Jonathan316 Learning to Sail 4 05-06-2004 06:07 PM
Coiling line DDogga Seamanship & Navigation 4 04-30-2003 04:03 AM
Permanent gas line fittings for outboard? BallastBoy Gear & Maintenance 2 04-08-2002 04:26 PM
centerboard line re-placement texas bob Gear & Maintenance 0 10-22-2001 10:28 AM
Norsail line ejgubbins Boat Review and Purchase Forum 0 10-20-2001 06:14 PM
