Old 08-21-2010
Atkinsericjr808's Avatar
Atkinsericjr808 is on a distinguished road
Mast steps
Hi everyone,
I'd like to remove the mast steps that came with my boat. Each step (approx. 20 of them) is secured to the mast with 6 screws (3 on top 3 on bottom).
Question.... Do I need to worry about all the holes in the aluminum mast or should I fill them with something after I remove the steps?
Old 08-22-2010
I would recommend filling them with a thickened epoxy putty, like MarineTex. The main reason for filling them is to prevent additional water from getting into the mast.
Just curious, but why do you want to remove the steps, they're quite useful to have and a PITA to replace. If you ever plan on going into the Caribbean or any other areas that have shallow waters with coral heads, you're likely going to want to have mast steps to give you a better vantage for spotting the coral heads. They're also useful when doing maintenance/repairs aloft.
Old 08-22-2010
SaltyMonkey is on a distinguished road
I'd also vote for keeping them on. They are quite useful and difficult to get on in the first place or replace.
Old boat fun means old boat work! daydreamer92 General Discussion (sailing related) 164 01-06-2011 12:36 PM
how to drop a mast on a soling? Ascension General Discussion (sailing related) 12 10-27-2010 12:22 PM
Tabernacle Mast - Pros/Cons jedowden C400 2 10-04-2010 11:18 PM
Mast or Spar shops in Seattle area? sparrow16 Gear & Maintenance 2 08-10-2010 03:35 PM
Identify this mast? GaryHLucas Gear & Maintenance 7 08-09-2010 07:29 PM
