Old 08-22-2010
jm1costley is on a distinguished road
Swing Keel Advice please
I just bought an '88 Nimble 20 that was only being used on fresh water in-land lakes. I am currently preparing it for a new bottom for salt water and need to address the keel which is actuated by a nylon rope which I would like to inspect further because it show signs of age and chaffing. This line runs from the keel through a tube into the cockpit just below the companion way. The hull has an inside liner and the keel trunk has 5 covers on it 2 small ones in-line aft, 2 large fwd, and one on top. I am guessing the aft covers will reveal a sheave that the line runs through and the fwd covers will reveal the keel pin. The top cover is either incoincidental or facilitates replacing the line, as I can see it has been removed before. It would be nice to get some feed back on this before I just start tearing into it and find myself doing something that I shouldn't have. I have tried emailing Nimble Boat Works but never received a reply. Your comments will be greatly appreciated.
Thanks
Mike
Old 08-22-2010
AllThumbs's Avatar
midlife crisis member
AllThumbs is on a distinguished road
Welcome to sailnet.
You are lucky to have so many access points for inspection. Most trailerables need to be on a hoist to inspect the centerboard and it's hardware from below. I don't know the boat but I would remove all access covers and see what you have. Take pictures and post here if you still have questions.
Eric
Keel modification Kwasiemoto General Discussion (sailing related) 11 09-21-2011 12:18 PM
Advice on glassing in wood keel spacer block bigwalt Gear & Maintenance 35 04-10-2011 07:21 PM
stuck keel beetoven General Discussion (sailing related) 12 09-29-2010 10:57 AM
H22 Swing Keel mpc7002 Gear & Maintenance 1 08-19-2010 12:10 AM
1973 Ericson 25 Swing Keel cb32863 Boat Review and Purchase Forum 0 08-16-2010 10:13 AM
