08-22-2010
Tartan 27' owner
Thoughtful comment from HS as usual.
On our Tartan 27' the fuel tank is actually above the engine with respect to the water line, so gravity actually feeds the fuel to the mechanical fuel pump on our engine and no need for a second pump at our fuel tank.
I am not sure how your G 30' is set up with respect to the relative height of the fuel tank to your engine. I have to believe that the 2nd fuel pump was added for a reason and if I had to guess I would bet that the 2nd fuel pump was added to insure that fuel would get to the engine fuel pump in heavier seas. If your boat was pitched forward or aft by larger waves this would change the relative height of your tank to the engine, perhaps even putting your fuel tank below the engine level - which would cause the fuel not to flow to the engine when you need it most.
By all means see if you can get the old pump beastie working again. OTOH, consider that a new Facet fuel pump from Moyer costs just over $100 and would likely last quite a while and give peace of mind if you get caught out in any waves while motoring. Just guessing but the 2-3 PSI pump would probably be fine for your application.
Disclaimer: this post is full of speculation.
