Not sure how often you need access to the second
rode, but here is a suggestion, for what it''s worth: Get a duffelbag with a drawstring top, and put a grommet hole center in the bottom. Tie a stopknot 6'' from the bitter end, feed the bitter end thru the grommet hole. Loose-coil the
rode into the duffel bag, chain and all, to the
anchor shaft. tie the drawstring.
When you need this
rode, haul it out of the locker, secure the bitter end, drop
anchor and
cleat off the
rode with proper scope. Leave the duffelbag with excess
rode tied to your boat on deck, To retreive, open the drawstring and loose-coil the
line back into the bag. Hope that helps, It works on my smaller boat.
