stuffing box repacking and flax size - Page 2 - SailNet Community
post #11 of 15 Old 03-11-2011
Maine Sail's Avatar
You guys are spending more than you need to.
Hamilton Marine sells Duramax Ultra-X for 1.68 ft in 3/16" PACKING ULTRA-X 3/16" SOLD BY INCH OR LBS 420" 176152
And in 1/4" for $3.00 per ft PACKING ULTRA-X 3/16" SOLD BY INCH OR LBS 420" 176152
Gore GFO from eMarine is $9.63 per foot in 1/4"!!!
I am VERY impressed with both Gore GFO and Johnson Duramax Ultra-X. What I am not impressed with is the knock off product made by Western Pacific Trading and sold by West Marine while similar it is not braided the same nor is it the same make up as Ultra-X or GFO.
Duramax Ultra-X is what I now use 90% of the time. Hamilton Marine sells it for next to nothing. The folks at eMarine a giving you bad advice on "drip free". Ask them if they plan on buying you a new shaft after it is eaten by crevice corrosion? The drips do more than lubricate they allow clean oxygenated water into the shaft log which helps prevent shaft corrosion.
BTW this shaft was set to "drip free" not "drips less". This particular shaft cost over $1500.00 to replace.....
______
-Maine Sail / CS-36T
Maine Sail is offline
post #12 of 15 Old 03-11-2011
Omatako's Avatar
Good post as always Maine.
But I can't stop thinking that the product you recommend sounds awfully like a good quality condom.
Arthur C. Clarke
Omatako is offline
post #13 of 15 Old 04-08-2011
jarcher's Avatar
Not trying to be a wise-a$$, but...
That stuff looks great, but if it is not going to be completely "drip free" what is the advantage? The bilge is still going to fill to the lowest level that the bilge pump can pump it out, about half an inch. Its just going to take a little longer to get there. Once its there though, you'll still have 1/2 inch of water in the bilge.
So I guess I'm missing the point.
Helios
Scampi 30 MK-IV
jarcher is offline
post #14 of 15 Old 04-08-2011
tommays's Avatar
It will drip way less for a MUCH longer time without the need for as much service and replacement
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #15 of 15 Old 04-08-2011 Thread Starter
Panhandle Sailor
dreuge's Avatar
Originally Posted by jackytdunaway View Post
Where can i get the Gore GFO? I am having a hard time finding it.
Take a look at : Packing-Shaft - e Marine Systems at "http://www.emarineinc.com/categories/Packing%252dShaft"
S/V Johanna Rose
dreuge is offline
1979 C&C 29 Mk1 stuffing box flax size? dreuge C & C 2 4 Weeks Ago 07:31 PM
