08-23-2010
1974 Catalina 22
Originally Posted by mdbee
Your motor was probably designed for a 50:1 (my guess) Among other things, this means the carb was jetted for this ratio. Find an oil thats compatible for that ratio.
I don't see how the carb jets are related to the oil ratio. AFAIK, the carb jets determine the air/fuel ratio which is something entirely different from the gasoline/oil ratio.
The carburetor will function at any oil ratio- but insufficient oil will cause accelerated wear on the bearings, pistons, and cylinders due to poor lubrication.
