Old 08-24-2010
bobmorning is on a distinguished road
Hunter 31 question - throttle friction lock
Our 84' Hunter 31 has a tendency to go to idle if we hit a hard wave. And by going to idle I mean the throttle lever physically falls back to the upright (idle) position. In rough seas you have to hold the throttle in position.
Is there a friction adjust in the throttle head or is this a down below in the engine spaces adjustment?
Thanks for any info.
Bob
Old 08-24-2010
If there's no adjustment at either end it's relatively easy to make your own..
Take a short piece of rubber hose the right size, slit it lengthwise and slip it over the transition from cable sheath to the moving part. Then, using two small hose clamps, clamp one end tight to the outer sheath, and apply just enough pressure on the sliding end clamp to add the required resistance to the throttle movement.
You can do this at which ever end has the better access.
1984 Fast/Nicholson 345
Old 03-28-2011
swiftibis is on a distinguished road
Bunjee
I use a bunjee to hold the throttle in place, I wrap it around the throttle to the SS handles. It works great for about 2 years when the bunjee disintegrates, although I might try the hose idea.
Old 03-28-2011
capttb is on a distinguished road
If it's an Edson Pedestal there is a throttle friction adjustment screw under the compass.
http://www.edsonmarine.com/support/P...ntrolInstr.PDF
"Democracy is two wolves and a lamb deciding what to have for lunch, Liberty is a well armed lamb contesting the decision."
Old 03-28-2011
montenido's Avatar
montenido is on a distinguished road
Capttb, thanks for the tip. I also use a small bungee to keep the throttle in place. I will lift the compass next time I am on the boat.
Cheers, Bill
Odyssey, '79 CSY 44 Cutter
Channel Islands, CA
"There is no unhappiness like the misery of sighting land (and work) again after a cheerful, careless voyage."
Mark Twain
Old 03-28-2011
scottyt is on a distinguished road
i have heard hunter will recommend a small rubber door stop, the wedge kind if you call them. I have seen it done, it does work and can be yanked out quick.
Old 03-29-2011
john1066 is on a distinguished road
You can add friction to the cable by fitting a small cable (wire rope) clamp over the jacketed section of the cable at an accessable location. Tighten the clamp gently until you have the required degree of friction at the throttle.
On a pedestal system the best access is usually at the engine end, with a cockpit wall mounted throttle, you can usually get access through an adjacent locker.
I've tried to load a simple sketch (.jpeg, 500 x 500) - which would have made the principle clear but the technology has defeated me.
John
