08-24-2010
Senior Mumble
Originally Posted by JSailer
One of the thing to check is your headsail halyard tension. If it is too slack (ot too tight) it could be part of your problem.
Also, in any kind of breeze, it is a lot easier to go downwind as too depower the headsailin the mainsail's windshadow.
If i don't do it on my boat, not only is it hard to roll the headsail in, but it also will roll super tight because of the tension on the sail and i end up running out of line in the drum before the sail is rolled all the way in.
If the halyard tension is too light, it can wrap around the forestay when furling, which will definitley make it harder to do. Also, it can fray the halyard, or worse, if you have a wire hlayard, it can cut the forestay, which happened to the PO of my boat.
Also, the efficacy of the downwind tactic depends a little on the size of your main. Our undersized main doesn't blanket enough for this to be useful in heavy air. I'm much better off heading into the wind and furling quickly while the jib flogs a bit.
