Old 08-24-2010
mrybas's Avatar
mrybas is on a distinguished road
Looking for Mast Steps, Recommendations?
I would like to add folding mast steps to my rig. Can anyone recommend a manufacturer? There are some aluminum ones on Amazon by "Sea Dog" for $20....are these any good? What material would be best (I'm guessing AL)- I have seen SS, chromed bronze, aluminum. Any recommendations on spacing them?
Old 08-24-2010
SVImpunity is on a distinguished road
Mast steps
I have 2 mast steps on my Bristol that I need to reach to attach the halyard. They are aluminium & lift & drop into place when not used. They have 3 mounting holes. Important not to use self tapping screws in the mast. I used captive nuts that are inserted similar to a pop rivet thereby providing a thread into which one can insert countersunk metal thread screws. The distance apart
is directly proportional to your leg length...make them so that you can step the maximum without over stretching your legs. The steps were about $25.00 each from memory.
Regards John Lake
Old 08-25-2010
Sequitur's Avatar
... a logical conclusion
Sequitur is on a distinguished road
I have forty-two folding nylon/glass-fibre MastSteps that go to within a metre of the top of my mast. They are very easy to use, light weight, strong and they do not rattle in the wind.
Cheers,
Michael
2007 Hunter 49
Old 08-25-2010
MARC2012's Avatar
MARC2012 is on a distinguished road
I have Al and they oxidize some,nothing strucual but unsightly.marc
Old 08-25-2010
night0wl's Avatar
night0wl is on a distinguished road
Can you share where you procured these steps? Most ive seen are stainless or aluminum.
S/V Jendai
Beneteau 343
Old 08-25-2010
I'd second getting the composite mast steps, since they're the least likely to have galvanic corrosion issues.
Old 08-25-2010
night0wl's Avatar
Exactly why I'm so curious.
I have thought about this project for a while. I dont want to use stainless on my aluminum mast...obvious galvanic issues. Less so with Aluminum, but unless the alloys used in the steps, the mast itself, and the fasteners to attach, there will be some corrosion there too.
BTW, what would you attach a composite or nylon material mast step with....5200, epoxy, something else???? I'm not sure if I trust my weight on an epoxy bond alone.
S/V Jendai
Beneteau 343
Old 08-25-2010
mitiempo's Avatar
Stainless machine screws with Tefgel.
Brian
Old 08-25-2010
Stainless steel or monel pop rivets with tefgel or Lanocote might also work well.
Old 08-25-2010
Sequitur's Avatar
The link I supplied above leads to a website under development, and a link there leads to Mad Dog Outfitters in Edmonton, from whom I ordered my steps two or three years ago.
I attached them using TefGel on stainless capscrews in drilled and tapped holes.
Cheers,
Michael
2007 Hunter 49
Mast steps Atkinsericjr808 Gear & Maintenance 2 08-22-2010 09:27 PM
RI/Narragansett Bay Recommendations? ralopata Pacific Seacraft 2 08-16-2010 10:37 AM
Recommendations for 2" voltmeter and ammeter radioguy Electronics 5 08-15-2010 10:34 PM
ICW guide recommendations glymroff Cruising & Liveaboard Forum 10 08-14-2010 11:45 AM
Thru Hull bedding compound recommendations bigwalt Gear & Maintenance 3 08-01-2010 07:40 AM
