08-25-2010
Paint
Hi Student,
We have a saying...."if it's in the water, gelcoat it...if not, paint it". If you are at all familiar with gelcoat, and if the boot top is partially submerged, I'd consider gelcoat as a permanent solution. All paints, need to breath or they blister so whatever you apply, enamel, epoxy whatever, will look fine for a while but will then need to be redone. There is a reason why all boat builders use gelcoat below the waterline. If you want to use paint, I'd consider raising the bootop so that none of it sits in the water. This has the added benefit, if you bring the bottom paint up higher as well, to help eliminate waterline fouling.
Hope this helps.
