08-25-2010
In theory, most bilge pumps should be wired for both manual and float switch operation. The float switch is generally used when the boat is unattended. The manual switch allows you to overide the float, if the bilge has just a bit of water in it, less than needed to activate the float switch, but possibly enough to need pumping out.
Having an off position is really useful. For instance, say you spill some diesel fuel into the bilge—you would want to turn the bilge pump off so as not to pump diesel overboard and incur a large EPA environmental remediation fine.  It can also be useful in the spring, when cleaning the bilge, and you don't want to have the mixture of water and detergent pumped overboard.
