-   -   Raymarine Pathfinder and DSC data (http://www.sailnet.com/forums/gear-maintenance/67751-raymarine-pathfinder-dsc-data.html)
wap1602 08-27-2010 08:34 AM
Has anyone connected a VHF with DSC to a Raymarine Pathfinder GPS?
Raymarine, when I can get them to respond to questions, speaks in tongues!
I have an ICOM422 with NMEA in/out wires and I cannot figure out where to connect them to bring in GPS positions.
tommays 08-27-2010 09:10 AM
For what ever reason there is no industry wide color code on the com wires :)
But each unit has output wires and input wires and a common/ground wire
The output from the GPS goes to the input on the radio
The output from the radio goes to the input one the GPS
The common wires connect to compleat the circut
You have to read the manuals to Id the wires
sailingdog 08-27-2010 09:13 AM
Does the Raymarine GPS have NMEA 0183 output? If so, then wiring it should be relatively easy. You need to check the manual for the Raymarine Pathfinder and see what outputs it has, and what version of NMEA 0183, if any, it has. Be aware that if the Pathfinder does output an older version of NMEA 0183, it may not be compatible with the iCom, which may require a newer version.
