08-27-2010
IMHP most mast walls are so thin i would clean BUT not sand away as there is not a LOT of extra in most mast extrusions and sanding of .035 could be a big deal around a speader
I cleaned up and painted and used a UHMW Tape on the underside of all the SS fittings to stop any more problems
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
If a dirty bottom slows you down what do you think it does to your boat To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
