Old 08-27-2010
joezucchini is on a distinguished road
Water tank on 1985 Starwind 19'?
Anybody out there with a Starwind 19' please explain to me what kind of water tank system came original with my boat. When I bought the boat I found a 1 foot hose descending from under the water pump, which I assume went into some sort of water tank, and a 4 foot hose descending from the sink drain, but I can't figure out where that hose exited the boat. And there was no water tank/reservoir of any kind. What was original on the boat, and any suggestions on how I can improvise to access water for the pump and how to drain it. Right now I'm using 2 one gallon plastic water containers - it works but it's rather cumbersome.
Thanks,
Joe
Old 08-27-2010
mitiempo's Avatar
The normal installation on most any boat is the sink drain to a seacock and through hull under the sink. This works unless the sink bottom is below the waterline. The water pickup usually goes to a fixed tank but could go to a suitably sized jug that is removeable for filling in a smaller boat. The vent on the tank will have to be open to pump water but could be closed when not in use.
Brian
Old 09-01-2010
WheresTheBrakes is on a distinguished road
I havent been to sailnet in a while and there are alot of starwind posts !!
I have a Starwind 22 MK2, and the PO had put a 5 gal gas jug (for water only under the vberth at the front, the sink drained to a seacock right below the drain in the sink..
we originally thought the gas can at the front was a spare, but upon closer inspection found the line that led back to the sink faucet pump !
~Joey
1984 Starwind 22
"Julianne"
Keeping Water Sweet paul323 Gear & Maintenance 56 04-23-2011 12:35 PM
Milky Bilge Water QuickMick Gear & Maintenance 3 08-26-2010 10:48 AM
Full Holding Tank? WanderingStar Gear & Maintenance 5 08-23-2010 07:47 AM
Water Heater Question braidmike Gear & Maintenance 8 08-14-2010 07:17 PM
Smallish diesel tank GilStump Diesel Engine Forum 1 08-10-2010 10:13 AM
