Blogs
User Name
  #11 (permalink)
Old 05-08-2003
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Super Moderator
Jeff_H will become famous soon enoughJeff_H will become famous soon enough
lazy jacks
Lazy jacks are a to each his own kind of thing. As someone who has sailed for over 40 years (time flies when you are having fun) and who single hands my 38 footer a lot, I find lazy jacks a real pain in the butt and a bit of a safety hazard for a singlehander. If I bought a boat with lazyjacks they would be first thing that I would remove. (Come to think of it I did buy a boat with lazyjacks and they were the first things that were not reinstalled when we stepped the mast). Then again I would not own a Lord Nelson on a bet either, so, what the heck, to each his own.
  #12 (permalink)
Old 05-08-2003
pblais pblais is offline
pblais is on a distinguished road
lazy jacks
My lazy jacks are on halyards so I can tighten or loosen them. With a full batten main I loosen the jacks and pull them back behind the winches to hoist the main and avoid battens hung in the jack lines. I was on a small Hunter last week that fouled the battens real easy. ven at that it was not toodifficult to have the right touch to get the main up. Without batten cars it didn''t come down all that easy but did contain the main from laying all over the boat.
Going down is no problem at all. With batten cars and lazy jacks if you lower the main she is going down straight and fast. That is really nice.
  #13 (permalink)
Old 05-08-2003
928frenzy 928frenzy is offline
928frenzy is on a distinguished road
lazy jacks
JeffH:
You usually provide good advice on many sailing topics, but I think your remark about "Lord Nelson" boats was uncalled for.
It''s ok by me that you don''t care for them, but your remark seems to imply that they are "bad" boats. I (and many others) do not think they are "bad" boats. They are indeed heavy, but they are solidly built, and have a very nice motion in a seaway. They were built to be used as passage-makers, and for that (I think) they are ideally suited.
They may not win many races, but those who sail them can rest assured they''ll arrive wherever they intend to go, even if it takes a bit longer. When I think of comparing a heavy boat to a lighter one, I think of the "Tortoise and the Hare" story.
~ Happy sails to you. ~ _/) ~
Sponsored Ad
  #14 (permalink)
Old 05-08-2003
Jeff_H's Avatar
Super Moderator
lazy jacks
I think that your point is well taken about my comment on the Lord Nelson''s. My comment was only intended to illustrate that we all have our own ideas about what works best for each of us or what suits our tastes. It was not intended as a wholesale slam on Lord Nelson''s nor were my comments intended to suggest that I think the Lord Nelsons are inherently "bad boats''.
Just for the record, the reason that I would not own a Lord Nelson on a dare has little to do with the Lord Nelson''s speed or lack there of. My dislike of the Lord Nelsons center more on certain construction and design decisions which I personally consider to be ''deal breakers'' in terms of being unacceptable to me.
I also consider the Lord Nelson''s roll and pitch patterns to be a very uncomfortable pattern to me and one that I personally would never choose to take offshore. This like or dislike of certain roll and pitch patterns is another matter very much subject to opinion and taste.
I would like to explain why I believe that roll or pitch motion comfort is subjective. One of the items that came out of US Navy research on motion sickness is that various individuals tolerate motion in different manners. There are two factors that control motion comfort, 1)speed or accelleration during the roll or pitch cycle and 2) the angle through which the vessel moves. They found that a near equal amount of people who tolerate quicker accelerations really can''t handle large roll or pitch angles and that others can handle large roll or pitch angles but can''t tolerate quicker motions and then there are still other people who can''t tolerate either.
Boats like the Lord Nelsons tend to roll or pitch more slowly but through a wider angle than would be expected in a lighter boat with a lower VCG. To many that slower motion is a more comfortable roll or pitch motion. But many, like myself, personally find these wider roll angles to be a less comfortable roll and pitching motion and at least in my case is one that really grinds me down quickly compared to the slightly quicker motions of a properly designed modern boat. Furthermore, some of the better modern designs not only roll and pitch through narrower angles, but because of their very low vertical center of gravity and carefully designed roll and pitch dampening characteristics also roll and pitch more slowly as well. In fairness, because of their lighter weight these modern designs do tend to have faster heave speeds but comparatively speaking in a general sense heave tends to be an inherently slower motion anyway.
I apologize, that after rereading my comments, it would appear that they could easily be construed to imply that the Lord Nelsons are inherently bad boats. They are not.
Respectfully,
  #15 (permalink)
Old 05-13-2003
jbanta jbanta is offline
jbanta is on a distinguished road
lazy jacks
Still, if any one has a list of parts and matierals for a retractable set of Lazy Jacks I am still intrested. $50 sounds like a pretty good deal..
  #16 (permalink)
Old 05-14-2003
lazy jacks
I don''t have the Lazy Jack plans right in front of me, so forgive me if I leave anything out that may be important.
First, you''ll have to decide just how far up the mast the top line will be connected or drawn through a block. In my case, I''ll probably connect 1/4" line to eyes screwed into the mast on each side 25'' up. Those lines will be about 15'' in length, and on the end of each of line will be a single small block. I''ll likely put a continuous length of 1/4'' line through the blocks to form the inverted "V" on the boom. That line will about 50'' in total length, as it has to go up, down, and around the boom twice. I''ll probably install a hook (facing aft) about 3'' on the bottom and from the end of the boom. I''ll probably install an eye about 4'' from the front end of the boom on on each side of the boom. Lastly, I''ll probably install a cleat that will be used to keep the system taught when in use. When the system is not needed, I''ll just slacken the line on the cleat, and move it forward of the boom, then tighten it again, and sinch it up tight on the cleat. If I''ve left anything out, I''ll get additional hardware (like more hooks or cleats) as the need arises.
Anyway, so far the list of hardware is comprised of 4 eyes, 2 small single blocks, 1 small hook, and 1 medium cleat. Lastly, it looks like I''ll need about 80'' of 1/4" line. Based on this list, I estimate the total cost to be about $50.
~ Happy sails to you ~ _/) ~
  #17 (permalink)
Old 05-14-2003
lazy jacks
Now that I''m looking at my Lazy Jack plans I''ve revised the previous message to the one below.
First, you''ll have to decide just how far up the mast the top line will be connected or drawn through a block. In my case, I''ll probably connect 1/4" or 5/16" or perhaps 3/8" line to eyes screwed into the mast on each side about 25'' up. Each of those lines will be about 15'' in length, and on the end of each of line will be a single small block. I''ll likely put a continuous length of the line (probably the same size) through the blocks to form the inverted "V" on the boom. That line will be about 50'' in total length, as it has to go up, down, and around the boom. I''ll probably use a medium sized cleat for to hold fast the open ends of that line. That cleat will go onto the boom about 4'' from the aft end, but clear of the main sheet. I''ll install hooks (facing forward) on either side of the boom about 4'' from the front end of the boom, but clear of the boom-vang. When the system is not needed, I''ll just slacken the line on the rear cleat, and move the lines forward of the boom, then tighten it again, and sinch it up tight, probably on another cleat that I will install on the mast below the boom. If I''ve left anything out, I''ll get additional hardware (like more hooks or cleats) as the need arises.
Anyway, so far the list of hardware is comprised of 2 eyes, 2 small single blocks, 2 small hook, and 2 medium cleats. Lastly, it looks like I''ll need about 80'' of the line. Based on this list, I estimate the total cost to be about $50.
  #18 (permalink)
Old 07-04-2006
mdriscol's Avatar
mdriscol mdriscol is offline
Good Crew
mdriscol is on a distinguished road
Thumbs up Joining In
Originally Posted by 928frenzy
To each their own. However, I''ve a friend who''s been sailing for about 20 years. Since he sails single-handed quit often, he decided to install a Lazy Jack system. He told me it was one of the least expensive and most useful modifications he''s made to his Lord Nelson.
Considering that the cost for all the material will be about $50, I can''t see how I can go wrong installing Lazy Jacks. ;^)
I don't see how you could go wrong for that money either. It's rare that one can do anything on a boat for that!
I'd love to make lazy jacks for my pocket cruiser, Lilliput. When she's in the water(not this season) I usually sail her alone. I've crewed on offshore deliveries and my experience with lazy jacks was positive. Can you steer me to the directions for them.
I've just discovered these forums, tho' I've belonged to SailNet for several years. Going to be a frequent visitor from now on!
Enjoy the short season.
  #19 (permalink)
Old 07-04-2006
FrankLanger FrankLanger is offline
FrankLanger is on a distinguished road
Jeff, please provide comment on lazy jack systems....
Jeff, I have always appreciated your posts, even if you sometimes express strong and personal opinions. You did clarify your comment on the Lord Nelson boats (interesting), but for purposes of this post, I am also interested in why you dislike lazy jacks--I recently purchased a 30 foot boat, without lazy jacks, and have been encouraged by others to install them as I do alot of single handing. I do have concerns about them interfering with the mainsail--both when raising the sail, but more importantly, when I want to let the main out on a broad reach. Therefore, I have not bought them, though I do find my mainsail hard to flake and manage on my own. Any comments to help me decide?
thanks,
Frank.
  #20 (permalink)
Old 07-04-2006
sailingdog sailingdog is offline
sailingdog is just really nicesailingdog is just really nicesailingdog is just really nicesailingdog is just really nice
I, personally, like having lazy jacks, as it makes it far easier for me to drop the main and reef or furl it. They can cause problems if you are trying to raise or lower the mainsail, and it has battens...but over all, I prefer to have them.
If you're new to the Sailnet Forums... please read this POST.
vB code is On
Lazy Jack - how to use? cyrusallen Learning to Sail 4 09-24-2002 05:42 PM
putting boat on jacks jolly_mon Gear & Maintenance 1 01-24-2002 11:22 AM
Lazy Jacks?? maureena5 Gear & Maintenance 12 11-15-2001 11:29 AM
Ted Herman Lazy Jack duffer1960 General Discussion (sailing related) 0 11-02-2001 08:45 AM
Lazy Jack System Comparison sehopkins Gear & Maintenance 6 06-07-2001 09:02 PM
Page generated in 0.9907 seconds (77.13% PHP - 22.87% MySQL) with 15 queries
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
