Drilling Hole in Fiberglass Hull - Page 2 - SailNet Community
 1Likes
post #11 of 17 Old 08-29-2010
mitiempo's Avatar
Hole drilling is pretty straight forward. If I am using a dremel to prepare the core for epoxy I use a vacuum held in the other hand and there is little or no stray dust.
Brian
mitiempo is offline
post #12 of 17 Old 03-15-2011
Drilling Fiberglass (hope I'm not dredging up a too old thread)
I need to enlarge the hole that my head vent goes through (vent tube is only 1/2 inch and need to go to 1"). So, obviously well above the water line.
1. Any secrets on how to "redrill" the existing small hole to the proper size?
2. Is there a best type or brand of hole saw? I bought a set from Harbor Freight and I guess they are worth what I paid for them (not much). I would think a fine toothed hole saw would be best.
3. A real "duh" I certainly believe one drills from the outside in. right?
As always,thank you for your help.
Ed Reiss
Being There
Freedom F38 #154
out of Marion, MA
ereiss is offline
post #13 of 17 Old 03-15-2011
tommays's Avatar
If the hull is not to thick you would be amazed what you can do with a pencil and a dremel with a good bit
you can also glue a plug into the hole and then holesaw to the new size
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #14 of 17 Old 03-15-2011
Learning the HARD way...
eherlihy's Avatar
I suspect that the " hole prevents you from using the center drill in the hole saw as a guide. Here is what I have done;
  • Use the 1" saw to cut a hole in a piece of " plywood.
  • Then take the piece of plywood (with the hole) and fasten it so that the 1" hole in the plywood is over the " hole in the hull (use clamps, and/or a helper).
  • Use the plywood as a guide for the hole saw.. Simply place the 1" hole saw in the hole in the plywood, and run it in reverse to cut through the gelcoat, then forward to finish off the hole through the hull.
Take care and good luck!
eherlihy is online now
post #15 of 17 Old 03-15-2011
mitiempo's Avatar
My Dremel sees a lot of use. A sanding drum on a Dremel flexdrive and a vacuum in the other hand to catch the debris makes the job not much longer than the time it took to write this.
Brian
mitiempo is offline
post #16 of 17 Old 03-15-2011
Thanks, just ordered my dremel. Certain that it will be a very handy tool to have. Thank you all for the advice.
Ed Reiss
Being There
Freedom F38 #154
out of Marion, MA
ereiss is offline
post #17 of 17 Old 03-17-2011
Liquorice's Avatar
To make a hole bigger with a hole saw, you use 2 hole saws.
1 the same size as the old hole, 1 the size of the new hole.
Nest them together on the same arbour ( some arbours won't take 2 hole saws, but most will. Harbor Freight sells one that's a little longer)
Use the smaller hole saw as the guide - real easy.
bandaidmd likes this.
sam :-)
Just because you're paranoid ...doesn't mean they're not after you!
Liquorice is offline
What not to do Maverick1958 Gear & Maintenance 26 09-30-2014 08:33 AM
The Salt's Corner Table smackdaddy General Discussion (sailing related) 129 06-18-2013 04:46 PM
The hull to deck joint ficaso FINISHED tommays Cal 0 08-28-2010 04:05 PM
Good Years and Bad Years MooreVOLS Boat Review and Purchase Forum 7 08-26-2010 11:04 AM
hull dupek General Discussion (sailing related) 2 08-26-2010 10:49 AM
