Head Problem - SailNet Community
Blogs
Old 04-21-2003
bjoc2314 is on a distinguished road
Head Problem
We bought a 2001 Catalina 310 near the end of last season so this was our first launch. The head, which worked fine in the fall, is not pumping in seawater, I have the thru-hull valve open and the head in "wet bowl" mode, but nothing happens. "Dry bowl" mode seems to work fine.
I suspest the problem is the Wet/dry bowl switch/valve. Any suggestions on a solution or cause of the problem would be apprecaiated. Thank you
Brian O''Connor
Catalina 310 #151
Anam na Mara
NY, NY
Old 04-21-2003
Head Problem
Old 04-22-2003
Senior Nappy Headed Ho
Denr is an unknown quantity at this point
Head Problem
If you did not winterize the head properly, that is to say by pouring Auntie Freeze not only in the bowl and pumped through the line to the holding tank but as well by pouring Auntie Freeze on the intake side of the pump, you could have damaged the pump assembly. Do not fear your MSD my son, you can rebuild it with a simple kit. It may save your butt some day. Pun intended!
Old 04-23-2003
h37skipper is on a distinguished road
Head Problem
Easy to check. Remove the inlet hose at the head. Open the thru-hull or, if it is too far away, have someone open it. If water comes out of the hose then the valve is bad. My guess is that the hose, thru-hull, or seacock is clogged. You should have a filter on that hose, right after the seacock or whatever kind of valve you are using.
Control Head fix for Merriman Steering System tdp Gear & Maintenance 1 06-09-2011 04:00 PM
What''s the best toilet (head) and... Myblueheaven Cruising & Liveaboard Forum 2 10-04-2003 10:52 AM
Head installation Irwin32 Gear & Maintenance 4 03-20-2003 01:23 PM
Rudder head corrosion aflanigan Gear & Maintenance 3 01-27-2003 02:01 AM
Head Problems bootsy1962 General Discussion (sailing related) 3 02-19-2002 08:26 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
