08-29-2010
Originally Posted by Hudsonian
It's a cinch to refill the overflow tank. Just fill to the line with solution of extended duty antifreeze.
This won't account for 2 to 3: of water under the engine. Look for leaks in the exhast system.
If it's raw water in the engine compartment then yes, it's likely an exhaust/RWC leak. But if the expansion tank needs regular refilling then there's a leak on the FWC side (too?).... so where is that ending up? Typically the RW pressure is a bit higher than the FW side... but such a leak will usually overfill the expansion tank, not the opposite.
To the OP - are you "topping up" with an antifreeze mix or just with water? Do you really have any antifreeze left in the system?
1984 Fast/Nicholson 345
