Old 08-30-2010
Zanshin's Avatar
Zanshin is on a distinguished road
Soft versus hard shackles
I have a problem with my Genoa clew knots getting stuck while tacking and have now made a soft shackle out of Dyneema and put eye splices on the end of the Genoa sheets so that I have a compact package with little to snag on.
While doing this I thought that I could use soft shackles instead of hard ones for other attachments such as the Genoa travellers (I tripped over one of those hard shackles last year while anchoring and broke my toe) and main outhaul and topping lift attachments. None of these lines have a tendency to flog, so chafe ought not to be a problem.
I'm using 8mm (6800Kg breaking strength) or 10mm (10,500Kg) Dyneema so strength isn't an issue.
Is there any reason not to use these soft shackles for these purposes?
Last edited by Zanshin; 08-30-2010 at 06:54 AM. Reason: Corrected spelling mistakes.
Old 08-30-2010
14432's Avatar
14432 is on a distinguished road
Many of the soft shackles are designed for halyards on racing boats and use in situations where they are under constant load for a finite period of time. In a situation where there is no constant load, be sure your design will not allow the shackle to undo itself - especially when used on deck and subject to being stepped on. Many of such shackles on the market have velcro retaining straps for this purpose. Nice thing about stainless shackles is they don't come undone.
Old 08-30-2010
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
Zanshin, (G'day btw, hope you are thriving....)
We're at the same stage. Just about to replace our headsail clew shackles with soft or as I know them "Dutch" shackles. I'm also wondering about doing the same for other uses.
14432, notes the problem of them coming undone when not under load. Have a look at the Colligo "Softie". It uses a rather ingenious method to keep the eye closed.
Softies XL Large Boat Series Soft Shackles | Colligo Synthetic Systems | Colligo Marine
There is a link to a U-Tube "how to do" video.
Old 08-31-2010
Zanshin's Avatar
TDW - I don't have a problem making shackles (I have a number of smaller ones for my hanked-on staysail) and use the method documented by Colligo. There are easier ways to tie the crown and cap knots than Colligo's method, though.
My question was about potential downsides to using them.
(Although right now I might have some shackles and no boat since the eye of "Earl" (Cat 4) just passed over Anegada, just a few short miles away from where my boat is stored....)
I hope that the new gov't changes the visa rules and I can head back to Oz in the near future.
Old 08-31-2010
tdw's Avatar
tdw tdw is offline
Zanshin, I take your point. I thought that perhaps the eye closer that the Colligo method uses would be the key point to expanding the field of opportunity for the soft shackles, preventing them from opeing when not under load. I'm going to use them wherever possible and keep an eye out for those areas where they don't perform. I guess its a case of 'suck it and see'.
Hope that your boat is OK. Keep us informed and remember that anytime you do make it back to Sydney you are due a beer.
Whether we get the Mad Monk or Gillard is still unknown but in either case I wouldn't use the word 'boat' on your application.
cheers and good luck with Earl.
td
Old 09-01-2010
Zanshin's Avatar
I spent some time last night trying to shake open a soft shackle without success. I think that if the shackle is not under load, then the outside sheath somehow gets hooked on something and pulled back and then the shackle flogs it might open up. I think for semi-permanent shackles such as for the travellers and genoa I'll use a thin line to whip the end shut so that it can't open.
I still am amazed at the strength of Dyneema every time I handle it, it is amazing stuff.
Old 09-01-2010
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
No reason not to use it. I'm going to change out my halyard shackles with these. Have already made a pair for the light air spin sheets, and use them for quick attachments at the tack on headsails as fine tune penants. Haven't 'tested' them flogging on the chute yet, but I think that'll be the best test I can come up with.
Merit 25 # 764 "Audrey"
Old 09-01-2010
tdw's Avatar
tdw tdw is offline
Well if you are using 8 and 10mm dyema on Zanshin then I figure 6 or 8mm is going to be plenty for our 34'er.
I'm going to pick up a few metres today, try and get them done over the weekend.
Old 09-01-2010
tdw's Avatar
tdw tdw is offline
This might make more sense for halyards......
http://www.sailnet.com/forums/genera...yard-knot.html
Old 09-02-2010
zz4gta's Avatar
How does that not slip or load up?
Masthead versus Fractional Cruisingdad Racing 29 11-12-2010 07:58 PM
