replacement engine for westsail 32 - SailNet Community
Blogs
Old 04-21-2003
honda2 is on a distinguished road
I am looking into buying a Westsail 32 Cutter and it has a Volvo MD2B Diesel Auxiliary. I am looking for a new engine that will fit the footprint of this old engine. Can anyone give me an idea on which engine they have used and had success with for this boat?
Old 04-21-2003
WHOOSH is on a distinguished road
Honda, a number of W32''s have been and are powered by Perkins 4-108 4-cylinder diesels.
Jack
Old 04-22-2003
fourknots is on a distinguished road
FYI - the 4-108 weighs about 200 lbs more than the Volvo MD-2
Old 04-23-2003
Nereus32 is an unknown quantity at this point
The Westsail 32 originally came with a choice of Perkins 4-108, Volvo MD3B, or MD2B. The MD2B is a little small for the boat, but many are still in service.
The replacement engine of choice was the Perkins M-50. However, the engine isn''t manufactured any longer. Today, I know the Westerbeke 44a and the new Beta Marine engine are being chosen as replacements. Replacing an engine usually means installing adapter plates for the motor mounts and resetting the shaft log for alignment. Depending on which engine pan is in the boat (assuming MD2B pan) installation shouldn''t be that big of deal. Check w/ WorldCruiser for specifics at www.westsail.com.
Atomic 4 is 4 lovers agent4change Gear & Maintenance 11 08-07-2011 06:14 PM
Pull engine switch replacement Neicy Gear & Maintenance 12 09-06-2005 07:05 AM
Engine Exhaust/Yanmar Problem plong Gear & Maintenance 5 08-30-2001 11:46 PM
Cat30 Exhaust riser blew up - Engine won''t start E_N_Z_O Gear & Maintenance 2 07-31-2001 07:55 PM
Raw Water in Engine wmwtlw Gear & Maintenance 3 02-25-2001 12:31 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
