mainsheet mysteries revealed? - Page 2 - SailNet Community
post #11 of 37 Old 08-31-2010
What is she looking for, faster sheeting or more power for handling the loads?
RXBOT is offline
post #12 of 37 Old 09-01-2010
IIRC, Denise is looking for more power, since the 4:1 is a bit underpowered for a 30' sailboat IMHO.
sailingdog is offline
post #13 of 37 Old 09-01-2010
The image you posted isn't a double ended mainsheet... it's a 6:1 with a 24:1 fine tune... and doesn't dump any faster than a traditional 6:1 mainsheet, but does give you more leverage for fine-tuning...
I don't believe she's looking for a faster setup, but a more powerful one.
Originally Posted by Hartley18 View Post
SD, I said "something more like this". The 4:1 coarse/fine set-up on the Harken web site is a mess and difficult to follow, so I posted something closer to what I had in mind. It's the PRINCIPLE we're talking about here!... Double-ended mainsheet, tackle on one end.. Silly Puppy!
If the 4:1 is too slow, she could probably trial a 2:1 coarse with a 6:1 fine adjustment, but with no pics of the current set-up it's a bit difficult to call. This might seem extreme at first (using the 'fine' adjustment for normal non-gusty mainsheet control), but you do get used to it - eventually..
Makes gybing quicker too!
Denise, I'm sure you'd be able to modify what you've got - it shouldn't be too expensive.
post #14 of 37 Old 09-01-2010
tommays's Avatar
We have the harken 4:1/8:1 combo unit, you pull one line for 8:1 power OR both for 4:1 speed and there both right in the same place
BUT its a LOT of rope to dump
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #15 of 37 Old 09-01-2010
I don't discuss my member
zz4gta's Avatar
What size and type is your mainsheet line?
What is the size of your main, in Sq Ft?
I'll assume its mid boom sheeting?
edit: I'm coming up w/ a rough estimate of 173 Sq Ft. Go with a 5:1 and use a single braid mainsheet of smaller diameter. 3/8" should do the trick. Look into Apex, salsa braid, etc. It runs free (which means reduced friction) is easy on the hands, and doesn't twist up like double braid.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #16 of 37 Old 09-01-2010 Thread Starter
One of None
deniseO30's Avatar
As I said before I have a 4-1 It was suggested I need 6-1 and I agree.
Is someting like what I have now. NOt sure of the model it's been a couple of yrs now.
I'd love to add a block to the boom. it's not mid boom more like75% back from the mast. and the Traveler is across the companion way. very rugged. but in stronger winds the mainsheet is very hard to pull. If I release it, it screams out when a gust hits. but I'm sure that's typical. I've a couple of spare Garhauer blocks laying about. would love to add one. make it 5 -1 maybe?
My last project!
deniseO30 is offline
post #17 of 37 Old 09-01-2010
zz4gta's Avatar
And to the original question, try a bunch of different ways to route the line on a tripple block. If you go all in the same direction the block will try to twist.
zz4gta is offline
post #18 of 37 Old 09-01-2010
zz4 is almost spot on in mainsail area I think. 174 main is a lot smaller than jib thats about 100 bigger I believe. Perhaps a fine tuning addition to her present set up would make trimming and just holding on to the sheet easier for her.
RXBOT is offline
post #19 of 37 Old 09-01-2010
zz4gta's Avatar
6:1 would definitely work, but then you'll have 50+ feet of mainsheet in the cockpit most of the time.
Depending on how the G blocks are made you might be able to lash one on the becket making it a 3 sheeve block. That would be the cheapest way to add a block. Otherwise, you may be in the market for something a bit more expensive.
I'll see if I can draw a picture.
zz4gta is offline
post #20 of 37 Old 09-01-2010
zz4gta's Avatar
zz4gta is offline
