mainsheet mysteries revealed? - Page 3 - SailNet Community
post #21 of 37 Old 09-01-2010
Have you actually used a rig like that, zz4gta? Does it tend to twist or bind or get fouled when slack and swinging during a tack/gybe?
... or I'm wrong.
Living aboard, currently in the Chesapeake
O'Day 37, still new to us
CapTim is offline
post #22 of 37 Old 09-01-2010
I don't discuss my member
zz4gta's Avatar
I have not used a rig like that. I think the key to the rig will be lashing the extra block at an angle to keep the mainsheet from rubbing on itself, but I don't think it'll bind up. One way to find out...
Merit 25 # 764 "Audrey"
zz4gta is offline
post #23 of 37 Old 09-01-2010
Originally Posted by deniseO30 View Post
... my traveler is down in front of the companion way
So is our's, Denise.
We had the same problem: A 4:1 purchase just wasn't cutting it for The Admiral. (She's usually on the tiller, because I'm usually playing deck-monkey--so I also handle the jib and she takes [most of] the mainsheet duties.) So we went to this:
We had two problems with that solution, both occurring when the middle of the boom started getting out over the rail and further:
  • The sheet would tend to ride up out of the sheaves on the top block, preventing it from running free. This was mainly a problem in easing the main in light air or trimming it in heavy air.
  • That bottom block, being as wide as it is, would lay down on the brackets atop the cam cleats on the windward sheeting traveler car, which would both prevent it from freely swiveling and since they were stainless, would chew up the cheeks of the block.
I suspect the reason we had these problems is because our boom is pretty low. That, coupled with the traveler being atop the cockpit seats and mid-boom sheeting resulted in the mainsheet becoming nearly horizontal between the blocks as the boom went out.
Finally, out of frustration and desperation, I called Harken tech support. They fixed me up with a custom lower block that's a fiddle block with a third single block added, stand-ups on both. Now our mainsheet runs like its on greased rails
The Harken tech that fabricated that for us told me they've had to do it before, and there was even discussion of making it a standard catalog part. I don't know if they ever did that.
The bottom block we originally had had the auto-ratcheting feature. The custom one Harken did up for us had the manual switch, instead. Don't care. The auto-ratcheting was neat, but the whole thing actually working well is even "neater."
I don't believe I have a picture of the block Harken fabricated for us, but, if I remember, I can get one this weekend.
Jim
SEMIJim is offline
post #24 of 37 Old 09-01-2010 Thread Starter
One of None
deniseO30's Avatar
I'll take some pics too.. been meaning to anyway. My 4-1 has Never twisted badly. It has a long line and it goes awaaaay out there on a release.
My last project!
deniseO30 is offline
post #25 of 37 Old 09-01-2010
ASA and PSIA Instructor
The best arrangement I have used is what Harken refers to as a two speed system, see examples 11-15 at Harken Mainsheet Trimming Systems
Basically the sheet is double-ended, but both ends come thru a pair of sistered camcleats. So you can fine tune with power by trinmming just one sheet, or trim or ease fast by handling both. Trimming both is no more difficult than a single sheet.
The system IMHO provides the best single solution for both power and speed.
sailingfool is offline
post #26 of 37 Old 09-01-2010
Once known as Hartley18
Classic30's Avatar
Dock
Great idea, SF - much neater and far more clever than anything I've seen before.
I particularly like this one, which will make life easier on my boat:
Thanks for the tip.
Classic30 is offline
post #27 of 37 Old 09-01-2010
Harken mainsheet rig
I have the Harken Main sheet rig on my 35' sailboat.
The traveler is mounted forward of the companionway and is level, which is nice as the mainsheet set does not change as you spill with the traveler.
It still needs the winch to pull it in or tighten it. There is a lot of line in the cockpit ( I bag it). I am not a racer so my adjustments are not fast. I have not had any issues with twisting lines.
CapnRon47 is offline
post #28 of 37 Old 09-01-2010
Just curious, how does this 6:1/24:1 dump the main more quickly than a 6:1???
Actually, yes, it works very well and is pretty common on boats like J-35's. The 6:1 works great for gross tune, and the 4:1 fine tune makes it all manageable in higher wind ranges... trav up and down, teak with the fine tune. We have the same on ours... the 6:1 can really load up, but you don't have quite enough to need the extra weight/expense/space for a main sheet winch... it's much faster.
puddinlegs is offline
post #29 of 37 Old 09-02-2010
zz4gta's Avatar
A 6:1 will dump just as fast as another 6:1. It's the same thing people.
I still believe a 5:1 is going to be the best thing for you. Also if you need a new mainsheet (remember you just increased the puchase), just tell your favorite rigger that you want a single braid. There's some really nice stuff out there, and the sailing world should branch out from the standard "lets put 3/8" sta-set on everything" attitude.
If you don't want to change the mainsheet, then splice on another 10 feet or however much you need in the next size smaller line.
Another way to get around buying a nother sheet is to make a pennant that attaches the mainsheet block to the boom. If you have a 1' pennant, you just reduced your mainsheet length by 5' (if you go with a 5:1). Really helps get the spaghetti out of the cockpit.
zz4gta is offline
post #30 of 37 Old 09-02-2010
Classic30's Avatar
Dock
..and increases the chances of you getting sconned something serious during a quick tack.
You'd have to learn to not only duck when the boom came over, but dodge as well!
