-   -   mainsheet mysteries revealed? (http://www.sailnet.com/forums/gear-maintenance/67889-mainsheet-mysteries-revealed.html)
deniseO30 08-31-2010 07:57 PM
I see multi purchase mainsheet controls on lots of catalina 30s and a few other boats.
Who would have some line drawings of various types?
Take this line.. now run from...fiddle block, a.. to fid b.. to block c... to block d.. to block e... :rolleyes: to block g.. oops f!... to g.. :rolleyes: down boom to turning block... to deck organizer.... through eyelet... to rope clutch... ::rolleyes:
sailingdog 08-31-2010 08:17 PM
Denise—
Harken has some really good illustrations of various mainsheet setups... see here: Harken Mainsheet Systems
deniseO30 08-31-2010 08:49 PM
WOW! I like that!
http://www.harken.com/images/main6.gif
but my traveler is down in front of the companion way :(
sailingdog 08-31-2010 09:09 PM
Originally Posted by deniseO30 (Post 638982)
WOW! I like that!
If you changed the block on the traveler car to a triple block with becket and cam cleat, like the one shown in the following image, you could use it and have a 6:1 mainsheet on your boat. :D
http://www.harken.com/images/main1a.gif
You obviously wouldn't need the three blocks by the mast... :D
Classic30 08-31-2010 09:12 PM
Denise, if you need to be able to dump the main quickly in gusts, that system isn't going to help you. :)
You need something more like this:
http://www.harken.com/images/main3.gif
Which I'm sure would be just a couple of blocks on the end of what you have now..
sailingdog 08-31-2010 09:18 PM
So, what you'd end up needing is the following:
THREE of these:
http://www.mauriprosailing.com/Merch.../HAR2600_F.jpg
ONE of these:
http://www.mauriprosailing.com/Merch.../HAR2630_F.jpg
sailingdog 08-31-2010 09:20 PM
Just curious, how does this 6:1/24:1 dump the main more quickly than a 6:1???:confused: :rolleyes: :confused:
IIRC, Denise's current setup is a 4:1... which I believe she mentioned in a previous thread.
deniseO30 08-31-2010 09:24 PM
Yes I've 4 - 1 now by Garhauer what I really need is $$ LOL
Classic30 08-31-2010 09:59 PM
SD, I said "something more like this". The 4:1 coarse/fine set-up on the Harken web site is a mess and difficult to follow, so I posted something closer to what I had in mind. It's the PRINCIPLE we're talking about here!... Double-ended mainsheet, tackle on one end.. Silly Puppy! ;)
If the 4:1 is too slow, she could probably trial a 2:1 coarse with a 6:1 fine adjustment, but with no pics of the current set-up it's a bit difficult to call. This might seem extreme at first (using the 'fine' adjustment for normal non-gusty mainsheet control), but you do get used to it - eventually..
Makes gybing quicker too! :D
Denise, I'm sure you'd be able to modify what you've got - it shouldn't be too expensive. :)
CalebD 08-31-2010 11:00 PM
I am not a fan of double or triple blocks on any sheet as I think they cause the line to twist and get quite squirrelly. I would use 'fiddle blocks' instead as the line seems to travel through them more smoothly without binding or twisting. They are also more expensive.
I like the idea of the extra means to let the main out with another lower powered block and tackle though. Thanks for that Hartley18.
Denise,
I'd save my money to upgrade to 'fiddle blocks' instead of 'double blocks' on my main sheet at 4:1 before I did anything else (if you haven't already).
This fiddle block would be undersized for your boat: http://www.defender.com/product.jsp?path=-1|118|103371|311571|311611&id=129859
as would likely this double block: http://www.defender.com/product.jsp?path=-1|118|103371|311570|311649&id=115792
I only use Defender to link the type of blocks because it is convenient and not because I have any affiliation with them and the pictures help describe the discussion.
