Old 08-31-2010
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
Holding Tank Vent
How do you vent your holding tank ?
Suggestions for how to cap the vent above deck would be appreciated. I'm concerned about water washing over the deck simply filling the tank through the vent pipe.
Also, how important/advisable is a macerator ?
The Womboat has a Lavac head. The Henderson pump on the Lavac performs as near as damnit as a macerator anyway, so I'm wondering whether I need the actual macerator itself.
Old 08-31-2010
jrd22's Avatar
Courtney the Dancer
td- our vent is on the outside of the hull, near the top and a bit ahead of midship. It isn't submerged when well heeled over although I'm sure that waves wash over it regularly in heavy weather. It has one of those fittings that has the cover over it and is open toward the stern. Hope that makes sense, I don't have a picture of it.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 08-31-2010
Hey Fuzzy—
I would recommend using a 1" hose for the vent line, per Peggie Hall's recommendations. Terminate the fitting as high on the hull as you can as close to the holding tank as you can using a standard 1" through-hull and cover with a stainless steel clamshell vent cover.
As for a macerator...not really needed. I would recommend plumbing the head directly into the holding tank, then adding a DIVERTER VALVE to the holding tank pumpout hose, and leading one side of the diverter valve to the deck pumpout fitting and the other to a Whale/Henderson Mk V diaphragm pump and then to the seacock and through-hull. This will allow you to dump the tank when out past the three-mile limit...
Old 08-31-2010
mitiempo's Avatar
My vent is in the hull just under the deck edge, about amidships. It is mounted so the opening is down and aft. It's like the one below currently but I may change it to a larger one for the new holding tank which will be gravity draining. It will be mounted at the back of a hanging locker just under the deck and everything will go into it so no "Y" valves will be needed. I also have a Lavac and am sorry I didn't change to one sooner.
Brian
Old 08-31-2010
mitiempo's Avatar
Dog's suggestion is a good one - that is probably what I will do.
Brian
Old 08-31-2010
tdw's Avatar
tdw tdw is offline
ah..OK then....vent in topsides not in the deck. That's good to know. Dog's vent idea, which I guess is what you are talking about JRD, looks good.
mtiempo.....how far above water line is your tank ? When you say gravity drain where is the through hull ?
Old 08-31-2010
mitiempo's Avatar
The through hull will be right below the tank. As everything will go into the tank first by leaving the through hull open it is in effect a straight pumpout. The tank will be mounted a few inches under the deck and its bottom will be above the waterline by 6" or so. The deck pumpout will be directly above the through hull so if there is ever a clog a rod can be pushed through to clear. I will finish when I haul out and install the through hull.
I have come across many installations like this from a Vega 27 to a Nicholson 35 as well as others and nobody has had a problem with it. And it couldn't be simpler.
Brian
Old 08-31-2010
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
The idea behind a large diameter vent hose is to allow simultaneous bidirectional circulation (in and out) via one vent. Smaller diameter hoses tend only allow unidirectional flow (in or out) at any one time. The other option is to have two small vents (preferably placed on opposite sides of the boat) so that air will follow any pressure gradient and flow through the tank, keeping it well oxygenated. I prefer the two small vent option, using vent thru-hulls like the one in Brian's post (post #4) above. The vents on my boat are on the side of the cabin (both on the same side actually, just angled a bit differently), rather than the hull. This avoids any chance of water siphoning into the tank (or worse) when the rail is buried. If you do put the vents on the hull, I would place them either close to the bow or on the transom as those are two areas unlikely to be submerged for any length of time.
Old 08-31-2010
tdw's Avatar
tdw tdw is offline
Sounds good to me. When you say "under deck" where is the thing actually located ? Forward head, outboard of that ?
I'm planning on ours going into our cockpit locker. The VDS 34 has an aft head not forward btw. I would prefer to avoid another through hull though.
Old 09-01-2010
mitiempo's Avatar
Yhe head is forward on the port side and the tank is going in the starboard hanging locker which is pretty deep. I will still have a good sizes hanging locker. Unfortunately I can't put the tank on the same side as the commode due to the structure already in place.
Brian
Keeping Water Sweet paul323 Gear & Maintenance 56 04-23-2011 12:35 PM
Virtual Fresh Water Tank mbettman Gear & Maintenance 10 08-31-2010 04:52 PM
Marine Toilet (good, bad, and ugly) anoser Bristol 12 08-28-2010 02:10 PM
Virtual fresh water tank for liveaboards... mbettman SailNet FAQ's 2 08-27-2010 07:49 PM
Full Holding Tank? WanderingStar Gear & Maintenance 5 08-23-2010 07:47 AM
