09-02-2010
Will—
If you google RS 232 pinout, you'll get the information you need. You might want to learn how to use google, since it can answer a lot of the basic technical questions, like what are the RS-232 pinouts.
BTW, the pinouts are 2 is Receive Data and 3 is Transmit Data, and 5 is signal ground. If you connect the NMEA OUT + to Pin 2 and NMEA IN + to Pin 3 and the NMEA OUT - and NMEA IN - wires to Pin 5, you should be good to go.
However, not all NMEA 0183 ports are RS-232 compatible... some are RS-422 ports, and some of the pickier RS-232 to USB dongles won't want to play nice with them, because they won't recognize the change in signal levels. IIRC, RS-232 is an unbalanced protocol, and RS-422 is a balanced one, with lower voltage signal levels.
