Old 09-01-2010
FEIERABEND is on a distinguished road
Replacing water heater
Feierabend here. Sail a Cat 30 TRBS and hot water heater just sprung the leak of death. Easy to change out from a connections point of view, but impossible to remove from boat as it was clearly put in before cabinetry. Anyone done this change out and are there any ideas for an alternate location for a new unit? Thanks
Old 09-01-2010
smackdaddy's Avatar
Last Man Standing
Hey fier - welcome to SN dude. You ought to re-post this question in the Gear & Maintenance forum. The gearheads won't see it here.
http://www.sailnet.com/forums/gear-maintenance/
BFS Gear: SNers started it....
Old 09-01-2010
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
Moved to Gear and Maintenance.
Feierabend......you really need to investigate dismantling that joinery....can you really afford to lose that amount of space on a 30'er ?
Depending on available space under v-berth or in cockpit locker seems a logical new location.
Water in engine compartment nightsky Gear & Maintenance 17 09-25-2010 06:40 AM
Water tank on 1985 Starwind 19'? joezucchini Gear & Maintenance 2 09-01-2010 10:45 PM
Virtual Fresh Water Tank mbettman Gear & Maintenance 10 08-31-2010 04:52 PM
Virtual fresh water tank for liveaboards... mbettman SailNet FAQ's 2 08-27-2010 07:49 PM
Water Heater Question braidmike Gear & Maintenance 8 08-14-2010 07:17 PM
