Old 09-01-2010
QuickMick's Avatar
QuickMick is on a distinguished road
Hydrometer testing
Ive got both of these... is there any reason to keep that old hydrometer around? I supposed if the meter ran out of juice i might have occasion to use it--but it seems like a longshot, unless the electrolyte reading offers some advantage?
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 09-01-2010
remetau's Avatar
remetau is on a distinguished road
I think that the hydrometer gives you a more accurate reading as to the state of the battery.
Don & Diana
sv Re Metau an HC33t
Old 09-01-2010
Vasco's Avatar
Warm Weather Sailor
Vasco is on a distinguished road
The multimeter can only give you the voltage at the terminals. It cannot read the specific gravity of the cells.
Rick I
Toronto in summer, Bahamas in winter.
Old 09-01-2010
oceanscapt is on a distinguished road
Send a message via Skype™ to oceanscapt
In reality, if the battery indicates it's bad, then knowing which cell(s) are weakest may not be helpful. However, if you can find battery acid you may be able to partially restore the weak cells, and for that you'd need the hydrometer unless you wanted to refresh all the cells.
Capt. Douglas Abbott
USCG/MCA IV/C.I./M.I. 500-ton Oceans
PADI MSDT
