Old 09-01-2010
Livinondreams's Avatar
Livinondreams is on a distinguished road
Deterioration around thru hull
I went and looked at a westsail the other day and was concerned when I noticed decay around a thru hull fitting. It seems to be a pretty deep gap at the area with the blue paint about 1/4 inch away from the fitting itself. Although this is a non cored hull, is that a serious issue or could it just be patched?
Old 09-01-2010
Stillraining's Avatar
Handsome devil
Stillraining is a jewel in the rough Stillraining is a jewel in the rough Stillraining is a jewel in the rough
Hey Livin hows it going!
Its not a deal breaker if its an isolated thing..
If it were me Id pull the through hull and grind back to good glass and rebuild it up...Install a proper backing plate and bolted flange seacock she will be better then new.
"Go Simple...Go Large"
Relationships are everything to me..everything else in life are just tools to enhance them.
The purchase price of a boat is just the admittance fee to the dance...you still have to spend money on the girl...so court one with something going for her with pleasing and desirable character traits others desire as well... or you could find yourself in a disillusioned relationship contemplating an expensive divorce.
Old 09-02-2010
Its going good,back on the prowl for another boat!
The westsail had a fairly recent survey and it seemed pretty good. Its just that one thru hull that has that problem but considering how thick the westsails hulls are I am hoping its not too serious.
Old 09-02-2010
JohnRPollard's Avatar
Moderator
Hey LOD, good to hear from you!
From your description, that doesn't sound too serious -- but would definitely need attention/repair. Also, it might be wise to seek a professional opinion (marine surveyor) before purchasing.
Which model Westsail is that you're looking at?
Old 09-02-2010
Its a factory finished 28. It needs a little love but it isn't in too bad of shape.
Old 09-02-2010
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
You might consider relocating the thru-hull (if you can) and grinding out, then patching the bad spot. That way you won't have to worry about the thru-hull being on a slightly weaken spot. An epoxy-glass patch, properly done, should be plenty strong. But, by moving the thru-hull to a "virgin" area, you can be doubly sure that the patch won't have any added stresses on it.
Old 09-02-2010
Regardless of whether you move the through-hull and patch the old spot or patch the old spot and keep the through hull there, I would highly recommend you follow Maine Sail's tutorial on installing through-hulls and use a decent fiberglass backing block, or one made of G10 garolite if you don't want to make up a backing block yourself. Bed the backing block in thickened epoxy so that it spreads the loads onto the hull evenly.
Old 09-03-2010
Handsome devil
Wha'ca gonna do with the contessa?
Old 09-03-2010
Doesn't sound too bad, maine sail's tutorial seems pretty helpful. As always thanks for the info!
Stillraining, I ended up selling the contessa to a local at the yard after I moved and was going to school and working. (I had started realizing that I may had bitten off more then I could chew with that project) But that way I was able to save up a little more money and now I can get a little less of a project.
Old 09-03-2010
Handsome devil
Right on...did you ever complete that diesel mechanics course?
The Salt's Corner Table smackdaddy General Discussion (sailing related) 125 10-02-2011 06:10 PM
Aluminium/steel hull slawomirjc Boat Buyers & Sellers Forum 2 09-03-2010 01:13 PM
The hull to deck joint ficaso FINISHED tommays Cal 0 08-28-2010 04:05 PM
What not to do Maverick1958 Gear & Maintenance 23 08-23-2010 02:11 PM
Hull blisters ? 75R20 Gear & Maintenance 3 08-01-2010 06:50 PM
