Old 09-03-2010
kjsailingSpring's Avatar
kjsailingSpring is on a distinguished road
Need Boat Ladder Suggestions
I have my boat on the hard and need to have a good ladder solution. I will be refitting every system on the boat and up and down extensively over the next 6 months. I want a rolling step ladder with a platform but they are expensive and my other half says there has to be a better solution. Does anyone have any great ideas that would make my other half happy?
Thanks -
Old 09-03-2010
tommays's Avatar
I have 10' and 6' step fiberglass step ladders the 6' is cheep the 10' was pretty big bucks BUT much less than falling off a cheep one
I also have some 16' planks i set up on blocks when i want to work on a large section of hull and do not want to keep moving the ladder
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 09-03-2010
Sabreman's Avatar
Sabreman will become famous soon enough
We use an articulated stepladder similar to the one below to make an impromptu scaffold. We place a 10' 2 x 6 board across the top so that we can walk from one end to the other. A 2x8 might be more reassuring for you. The result is a very sturdy platform that is stable and strong enough for both myself and my wife. Ours is a cheap-ish Harbor Freight ladder, but any articulate ladder should work. We've used this setup without issue for about 20 years.
Werner M1-8-16 8'/16' mm Type I Aluminum Articulated Ladder
Sabre 38 "Victoria"
Old 09-03-2010
I'd second the Werner ladder Sabreman points out... very useful and far more versatile than a typical stepladder.
Old 09-03-2010
QuickMick's Avatar
QuickMick is on a distinguished road
maybe come up with some projects around that house that you would love to do.... if only you had a quality ladder! Maybe that way the purchase would have added value...
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 09-03-2010
Sabreman's Avatar
I extend the ladder to it's full 16' length for painting the exterior of the house and fold it in half (8') for getting to our cathedral ceilings (at home, not on the boat ).
Super versatile ladder. I wouldn't be without it, regardless of whether I had a boat.
Sabre 38 "Victoria"
Old 09-03-2010
Keep the great suggestions coming!
I like the Werner ladder idea but what about going up it with 50 pounds of ballast in my arms? I guess I could rig a pully system around a platform and hoist gear and supplies up to the deck via the dingy davit. I'm still not convinced I don't need to shell out for a rolling step ladder. This is the one I'm looking at: Used Warehouse Rolling Ladder 12 Step
Tommays suggestion was very helpful too. I will do that for fiberglassing the hull, sounds perfect!
Thanks guys!
Old 09-03-2010
Capnblu is on a distinguished road
I have refit my Tayana 42, and I can tell you, ladders of ANY TYPE suck. Build yourself a set of stairs 4' wide, with a landing on top at least 8' X 5'. Put a hand rail up both sides, and make the deck of the landing at the same level as the deck of the boat. Nail asphalt shingles to each step, and onto the platform on top. You will be walking those stairs a million times with heavy crap. build a post on a corner to hook up a come along or rope and pulley system to raise and lower all the things you do not wish to fall all the way down with. You will never regret it if you do.
Why, why, why?
Old 09-03-2010
This only really works if you own the place that you work on the boat at... most people need something that is a bit more portable a solution, rather than something so permanent. It might also work if you have a long-term relationship with the yard you're keeping your boat in.
Old 09-03-2010
I would try really hard to negotiate with my yard to allow a good set of stairs. Since KJ already mentioned a rolling set, I didn't see space or perceived permanence as a problem. My stairs can break down in under half an hour with a cordless screw gun. I used 2 X 12's for the stringers, 2 - 2X 6's for each tread, and 2 sections of brick layer scaffold for the tower. I have the entire boat surrounded by scaffold, and can walk up the stairs and either work around the topsides, or step onto the deck carrying both hands full. I just can't imagine trying a refit going up and down a ladder...
So what type of boat did you buy KJ? What will the scope of your refit involve?
Why, why, why?
Boat explosion finally reaches a conclusion Hartley18 General Discussion (sailing related) 23 10-06-2010 08:24 AM
Our new (to us) boat, and it's maiden voyage rhsanborn General Discussion (sailing related) 10 09-01-2010 05:21 PM
What not to do Maverick1958 Gear & Maintenance 23 08-23-2010 02:11 PM
Use a DC Power Supply? Tree Electrical Systems 17 08-20-2010 01:03 PM
What makes a boat "Blue Water" worthy HappyPappy Boat Review and Purchase Forum 15 08-08-2010 01:08 AM
