Old 09-06-2010
ncapener is on a distinguished road
Spinnaker Size
How are spinnakers sized for a boat? How do I determine luff, leech and foot measurements for my boat?
I would like to buy a used one and need help figuring what works for my boat.
Thanks,
Neal
Old 09-06-2010
DwayneSpeer's Avatar
Old Fart
DwayneSpeer is on a distinguished road
Do you want a spinnaker, genaker, or cruising chute?
Hey, can one of you guys pass me a crab?
Old 09-06-2010
I would like to be able to measure for all three. Main goal is to get a used large downwind sail. There is slim picking and I probably get what fits size wise.
Neal
Old 09-07-2010
JimsCAL's Avatar
JimsCAL is on a distinguished road
From Atlantic Sail Traders website:
"Measuring for a Spinnaker is very easy. The only dimensions needed are the I and the J measurements. Hoist a tape measure to the top of the mast with the Spinnaker halyard. If you do not have a dedicated Spinnaker halyard use your Jib halyard. Remember to tie a line to the halyard in case your tape breaks. Measure down to the top of the working deck, not the cabin top. This is your I dimension. Lower the tape measure. Now measure from where the forestay connects at the bow, back to the base of the mast. This is your J dimension.
If you are racing, most PHRF organizations limit the maximum luff length of a Spinnaker to the I dimension. The maximum foot dimension is 180% of the J dimension.
If you are a Cruiser, there is a lot more flexibility to the size Spinnaker you can use. The luff length should be within 10% of the I dimension. The foot dimension can be anything, but ideally it should be from 160% to 200% of the J dimension."
Old 09-07-2010
tommays's Avatar
What gear do you have as a traditional spinnaker is gonna be the cheep part if the boat does not have all the gear to use it
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 09-07-2010
mikehoyt's Avatar
mikehoyt is on a distinguished road
You can look up these measurements on U Sailing site here http://offshore.ussailing.org/Assets...Dimensions.pdf
Mike
Old 09-07-2010
catamount's Avatar
catamount is on a distinguished road
Indeed, if you are looking to fly a symmetrical spinnaker off an articulated pole, you will need: (1) the pole, (2) some way to attach it to the mast, usually a car on a track, (2a) rigging for adjusting the height of the mast car, (3) a pole topping lift, (4) a foreguy or pole down-haul, (5) turning blocks for your guys (snatch blocks to the toe rail?), (5a) the guys, (6) turning blocks for your sheets (snatch blocks aft), (6a) the sheets, and this is all assuming you have an appropriate halyard (or two) already.
If on the other hand, you intend to fly the spinnaker tacked to the bow (typical of assymetrical spinnakers, cruising chutes, and gennakers, but can also be done with a symmetrical spinnaker), then you just need the halyard, a tack line and turning block on the bow, sheets, and turning blocks aft.
Good Luck!
Peterson 34 GREYHAWK, West Boothbay Harbor, Maine
, a new voice for ocean conservation
stuffing box repacking and flax size dreuge Gear & Maintenance 14 04-08-2011 07:38 AM
Slip size and boat size. rikbass Announcements and Suggestions Box 12 09-14-2010 02:52 PM
1979 C&C 29 Mk1 stuffing box flax size? dreuge C & C 1 08-25-2010 01:39 PM
Spinnaker pole height: no downhaul, no adjustable height aarhus Learning to Sail 5 08-16-2010 05:37 AM
Cal 21 Spinnaker? sailnova Cal 0 08-13-2010 10:55 AM
